viewsonic vx2835wm
  • testas86
    • May 2010
    • 140
    viewsonic vx2835wm
    the unit turns on and the screens backlight seems to come on but no actual video its just lit up black. ive taken it apart and saw some blown caps on the video board and replaced the 1 blown cap and all surrounding caps. ive also tried each transformer by its self and every time the screen does the same thing. i tested the voltages of the transformer and one of them seems a little weird so i wanted to replace it. if anyone could help me trouble shoot more on this tv and help me find a transformer that would be great! thanks
    transformer number seems to be
    2874015000
    m b 0740a
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: viewsonic vx2835wm
    Did you check the transformers soldering?
    Big parts like transformers often end up with cold-joints when they wave solder the boards.
    Mann-Made Global Warming.
    - Dr Seuss
    • testas86
      • May 2010
      • 140
      yes ive resoldered every transformers joint
      • testas86
        • May 2010
        • 140
        so i took it all apart again and resoldered all the transformers on the power supply as well just in case. i also disconnected the tcon board from the tv and turned it on and i got nothing at all. so i was wondering if that means it is in fact the inverter board cus shouldnt i atleast get a flash on the screen showing that the bulbs are turned on even if then tcon board isnt plugged in or working?
        please any help would be greatly appreciated.
        • notallbad
          Sony Cmt-cp33md power transformer blown
          by notallbad
          Power transformer has open circuit on the 230v primary side, its tapped for 115v too which is also open so most likely the thermal fuse has blown. It doesnt look like it would be possible to open it up to check the thermal fuse so looking to replace.
          What are peoples thoughts on repair?
          replace the one transformer with 2
          replace like for like, though unlikely to find a direct replacement...
          01-22-2023, 03:47 PM
        • Hounddoghill
          DPS285BP 5v standby transformer blown
          by Hounddoghill
          Sharp TV LC-80LE633U
          Power supply board DPS 285BP Run TKB096WJQZ
          Standby transformer markings (attached picture)
          MP-130I(01)
          AV-DP11153 Delta
          Dcum 1244(03) H6P
          So an event in the primary exploded the cap (C7901)on pin one of the Standby circuit IC. So after replacing a couple diodes a the 2.2ohm resistor(fuse) I found the transformer inputs are open.
          Anyone know about replacements for this transformer?
          I suspect the original is not available.
          https://www.badcaps.net/forum/images/smilies/silly.gif
          02-04-2022, 03:22 PM
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • cmlewis89
          LG 47LB5DF blown power supply board
          by cmlewis89
          Hi folks,
          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
          09-03-2024, 07:50 PM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
