First time poster in need of help and ideas Philips 42pf7320...
  • mistamista
    • Nov 2011
    Hello all. I found this forum at the suggestion of a friend who said that you guys are "bar-none, the most helpful folks on the web". After reading some other posts, I think it's fair to say that you guys are in a very good position to help me out.
    So, I bought a Philips 42pf7320 about three years ago at a local repair shop who had recently replaced a few internal boards. It was working very well in his shop and the picture is astoundingly good...or was good anyway. The power supply died last month and I decided to go ahead and take the chance that the power supply alone would get it up and running. Suffice it to say that I was wrong.
    The set turns on with both, the remote and power button as expected. I hear the "click" as the circuit breakers cycle on and I get a green LED that stays on regardless of how long I leave it on. The trouble is that it seems to go completely insane after about 30 seconds. The plasma screen flashes hundreds an hundreds of red and green pixels and does so in a rhythmic pattern until you shut it off. It doesn't have any issues with the power supply and I am reasonably certain that the "logic main" board and "X-main" board are in working order as they are nearly brand new. I'm unsure of the "Y-main", "Y-buffer" and "x-buffer" but none of the caps show any signs of damage and do not seem atypically hot to the touch.
    Now, my concern is that I've gotten in over my head as I'm no troubleshooting aficionado, but I am very adept at working on electrons. I'm simply not sure where to begin the narrowing down of the failing parts. Do you guys have any ideas for me?
    Thanks so much,
    Michael
  • cmj21973
    • 267
    Re: First time poster in need of help and ideas Philips 42pf7320...
    Service manual:
    If not right SM then:
    Look here for the one you need.
    http://elektrotanya.com/
    Photos:
    1) Overall pic of the boards, in the set and connected.
    2) Individual pics of each board. (component and solder side)
      Sounds like Y-sustain failure. You could have tested the power board and verified that the power board was actually good before replacing it using a multimeter.
      • mistamista
        • Nov 2011
        Originally posted by cmj21973
        Service manual:
        Photos:
        I actually bought the long-form service manual, but I'm unable to track the board in failure as they all seem to show proper voltage and lack and visual component failure. Based on the info that I gave, would you feel confident that it's the y-sus board?
        • mistamista
          • Nov 2011
          Hi Tom and thanks. The power supply was going to be replaced either way. It had the faint smell of PCB board being cooked from the original failure...so it was due. Everything I can see leads me to believe that it
          s the y-sus too, but I'm wondering if the Y-sus took the buffers too. Is there a means to test them other than the voltage? I ask because all of the components show proper voltage...but still, there's the pulsing blob of glowing red and green pixels.
          One thing to add. I did a quick break down and rebuild this morning just to double check all of my connections, but everything was solid. But I tried something new and got a bit more info. When the pulsing pixels are on the screen, if I push the menu or PIP button on my remote, the pixels shift in volume and location. That sounds to me like a failed buffer set-up. Could it be both buffers and the y-sus?
            Usually the problem you are seeing is caused by the ramp down MOSFETs not activating properly. So the pixels are firing randomly and chaotically, with a little control over the picture (which is typical.) Sometimes the buffers can be damaged by the sustain, and the buffers can also damage the sustain itself. It's advisable, unless you have an oscilloscope to test the sustain board, to replace the buffer(s) and sustain board at the same time with known good parts.
            I notice though that it's not even a HD panel: it's just 852x480 pixels. It will probably cost a lot more than it's worth to repair, but it's your choice. You could buy a used 480p plasma for less than the price of the repair if you shop around.
            • mistamista
              • Nov 2011
              Thanks Tom. Yes, the TV is the older 720p standard, but I love using it on my video games and portable hard-drive media as it has excellent up conversion from SD to HD. I'd love to get a new set without a doubt, but this was a one-time trial that became a favorite pass-time. I think I'll see if I can find all three boards together at a shop or on a surplus website. The problem is that most of these sets die the same way, or so it seems.
              Again, your time is very much appreciated.
              Michael
                Michael
                No, it's not even 720p; it's just 480p (slightly less than a standard PAL CRT, the same as a NTSC CRT.) That being said, I can barely tell the difference between 1080p and 720p at a 10ft distance, and 720p and 480p probably wouldn't matter too much to me as I don't watch that much HD. But for a HTPC 720p is a must. Anyway...
                Do have a look around on craigslist for people selling off their old plasmas, it may be cheaper.
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • crozoki
                  Philips 65PUS6554/12 one time backlight flash
                  by crozoki
                  Hello
                  I have Philips 65" TV (65PUS6554/12).
                  Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
                  Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
                  Power board TPV 715G9187-P01-008-001S
                  Main Board 715G9907-M01-B03-005K...
                  09-03-2022, 05:47 AM
                • ahmedtou
                  HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                  by ahmedtou
                  help me please
                  I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                  When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                  I will share all the details with you, including the disc information.
                  Code:
                  HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                  Current Profile: BD-R
                  Disc Information:
                  Status: Empty
                  State of Last Session: Empty
                  Erasable: No
                  Free Sectors: 12,219,392
                  Free Space: 25,025,314,816 bytes
                  Free Time: 2715:27:17 (MM:SS:FF)
                  Next
                  08-27-2025, 08:49 AM
                • titomno2
                  Gaming Laptop Zephyrus S17 TFT not detected every time !
                  by titomno2
                  Hi guys,
                  I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                  So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                  On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                  Then the screen won't work for a long period of time.
                  If I wait 1 or 2 hours it work again most of the time.
                  When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                  01-19-2025, 08:27 AM
                • Sharpa
                  Repair attempt Philips 55OLED804/12
                  by Sharpa
                  I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                  The symptoms when bought: Philips logo appears then tv turns off
                  Things tried so far:
                  1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                  2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                  Today, 08:30 AM
