LG 42PC3RA SMPS power_ysus problems on/off/on click and fixes
  • slappala
    • Nov 2011
    • 44
    #41
    Re: LG 42PC3RA SMPS power_ysus problems on/off/on click and fixes
    Originally posted by tom66
    Same here. No idea how it fixes it but it does. Seems very common with LG plasmas.
    I guess U702 monitors the AC primary's two sides with these optocouplers.
    When the 3-4 pins are joined the U702 thinks the AC is on all the time by circulating the 5.v signal back to the IC. Basically thinks the opto is on state what it really is also except during the 200ms at the start where the opto ON signal would be lost sometimes.
    Yep, something wrong with the optos or the AC primary waveform at the start..TV works now again without hickups so before some PSU components fail completely I will just use it like it is
      I figure the same. Pins 3 and 4 make the optocoupler seem always on. It might be the PFC bus caps aging or the TL431s being damaged. (These sensed the voltage on the primary on my model.)
      • MoDu
        • Portugal
        #43
        How long have you had this "hack" force tv to not auto-shutdown?
        I've had all the problems described here, even went as far as replacing all big caps and even a whole YSUS board, but alas, it remained the same.
        I shorted out the suggested pins on the opto-couplers and so far so good.
        Will this kill my tv in a few months? Or will it just keep going until a fuse or a IC burns?
          I had it running for a month, but sold the TV on after that due to the LG "sparklies" issue.
          The only disadvantage that I can see is the audio doesn't mute on power off, so you'll get a loud crackling sound. This is a common phenomenon with audio amplifiers. Some can detect the failure of their supply voltage and mute immediately, whereas others require an external signal. AC detect provides this signal, along with the signal to the processor to tell it to keep running.
          • MoDu
            • Portugal
            #45
            Audio is a non issue for me, I don't use the TV's audio at all.
            I was able to easily fix the sparklies with some tinkering on the Var resistors, they're now invisible at a regular viewing distance.
            So my only concern right now is whether this will destroy what's left of the Z board.
              I doubt it will do any damage to the sustain boards. My 42" actually ran for half a second with this bridge made, you could see picture slowly fade out before it cut out completely, so it does shut down reasonably cleanly.
              The speakers will make click noise even if nothing normally comes out of them, so to avoid this simply unplug the speaker connector on the AV board (board with SCART etc on it.)
              • MoDu
                • Portugal
                #47
                Thanks for the tips.
                • MoDu
                  • Portugal
                  #48
                  I tried turning on the sound, to see if I could hear the speaker thump you mentioned, but it was barely noticeable. It only happens when I unplug the cord, simulating a power outage.
                  BTW, disabling the speakers in the menu is enough to NOT have this side-effect.
                    Great, so there is no issue. Yes, it only happened on mine when power is unplugged, and only then on bright scenes. Dark scenes caused no click. I figured this was due to the standby supply lasting longer than the main supply so the TV could recognise a power failure and cut off the speakers.
                    • er_rusty
                      • Jul 2013
                      • Spain
                      #50
                      Okay, pin 4 on the optocouplers is on the phototransistor side.
                      They're the only signals coming FROM the primary to the secondary, normally the signals go to the primary side from the secondary.
                      Need a closer pic of under these devices.
                      You will probably need to place a solder bridge between pins 4-3 on both optocouplers. That's how I fixed mine.
                      Hi to all!! I'm new, I have a LG 42PC1RV-ZJ plasma TV that had the same symptoms slappala TV. I think that the solution can be the same.
                      Please, i don't understand very well what i have to do:
                      Maybe I have to place a solder bridge between pins 4 of one optocoupler to pin3 on the other???
                      Or I have to put a solder bridge between pin 4 of a optocoupler to pin 3 on the same in booth optocoupler?
                      TOM66 help me please!
                      Thanks a lot!!
                        Pin 4-3 on BOTH optocouplers. i.e. 2nd choice.
                        Only bridge the devices which have 4-3 on the SECONDARY (isolated side.) Do NOT bridge them on the primary.
                        • er_rusty
                          • Jul 2013
                          • Spain
                          #52
                          Thank you!
                          • benfinland
                            • Jul 2013
                            • 20
                            • Finland
                            #53
                            What are these optocouplers? And where? I was wondering about bridging them to see if the tv will fire up
                              Not relevant to your model unfortunately.
                              • er_rusty
                                • Jul 2013
                                • Spain
                                #55
                                It works!!
                                Thank you again!!
                                  This has to be the tenth TV with this issue so far fixed. Glad to hear, enjoy your TV!
                                  • Shipmaker
                                    • Feb 2014
                                    • 36
                                    Hallo everybody I m new on this board!
                                    Thank you for your solution, because i v got the exactly same powersupply in
                                    my LG42PC1RV and in nobody could help me, but now!
                                    I also recogniced while I looking tv that a little green snow apperes, to see
                                    in black parts of tv picture and while changing programm.
                                    But my Question is : How do you bridge with solder or with a wire?
                                    (Please, forgive me my bad english, i am german)
                                    Thanks!
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      #58
                                      You can bridge the opto with blobs of solder done carefully this is fine.
                                      --But,--As Tom says--Only bridge the one side of the optos.
                                      The green spots can be adjusted out sometimes but the official cure is a Software Update to the Contol-Board.
                                      --Let me know if you want control-board update, I have the complete kit to update lots of LG sets--including the PC1 series....
                                      TELEFIX
                                      • Shipmaker
                                        • Feb 2014
                                        • 36
                                        Thank you for the fast reply,
                                        now i try out to fix my tv with an solder bridge!
                                        I dont now if this kind of Modell LG 42 PC 1 RV is able to update on software side
                                        but i will take a look on my service manuall and tell you if it s possible.
                                        But again Thanks a lot!
                                        • Alastair E
                                          Chief Womble
                                          • Mar 2013
                                          • 1963
                                          • U.K.
                                          #60
                                          According to my data--its updateable, Its the Control-Board firmware that needs doing, not the mainboard or the set itself.
                                          Tell me the numbers written on the back of the banel metal-work, be something like 42X3####
                                          TELEFIX
                                          • Salvatore057
                                            plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                                            by Salvatore057
                                            I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                                            Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                                            I am lost, should I change the YSUS board? Is the YSUS board damaging...
                                            04-29-2018, 01:29 PM
                                          • JDC
                                            LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                                            by JDC
                                            Make and Model: LG 60PB6650-UA
                                            Issue: Turns on, no backlight, can hear static (no channel)
                                            I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                                            The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                                            This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                                            09-13-2018, 02:12 PM
                                          • dkneyle
                                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                            by dkneyle
                                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                            02-01-2022, 02:08 AM
                                          • legg
                                            LG 42PC3 buffer output doesn't follow YSUS
                                            by legg
                                            LG42PC3D -UD originally with green lamp but no display or audio.
                                            Owner says was working, then went 'pop'.
                                            All 5V caps bulging. replaced.
                                            All PSU output voltages within spec but -Vy is low on YSUS.
                                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                                            Y scan buffer test point does not follow YSUS output below -50V
                                            Note: This unit seems to expect YSUS output to park at -Vy in between
                                            drive signal pattern periods. A replacement drive signal board confirms this....
                                            11-18-2021, 11:49 AM
                                          • abhishekkumar1902
                                            Huntkey HK340-72FP SMPS shut on load above 2 amps
                                            by abhishekkumar1902
                                            I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                                            I have checked the following:
                                            1. All output caps are OK, and all output rails read correct voltages at no load
                                            2. All output diodes are OK
                                            3. NTC is ok
                                            4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                                            5. No short in main switching MOSFET
                                            6. All other components...
                                            12-18-2022, 09:52 AM
