Random Vertical Lines on Samsung LCD TV
  • agbayh
    • Sep 2011
    • 6
    I'm new to these forums. I have a problem with my Samsung LCD TV. There appears vertical lines where ever there is text on the screen. See my picture attachced. I asked a local TV repairman and he said I have to replace the whole pane. Could this be fixed by replacing some kind of printed circuit board that drives the lcd panel? Thanks for all the help in advance.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Random Vertical Lines on Samsung LCD TV
    It could be the tcon, it could be the panel.
    PlainBill
    • agbayh
      • Sep 2011
      • 6
      Thanks PlainBill. I'll try opening this unit up and see. It's already broke, what is the worse that can happen other than electricute myself. I promise not to do that. I was suspecting it to be not the panel since the lines follow the overlayed OSD type display. The adventure begins. Thanks again.
        The panel displays exactly what is sent to it, as does the T-con. Neither differentiate between OSD and video.
        • agbayh
          • Sep 2011
          • 6
          OK.. Thanks. So if the vertical lines changes location depending on what is being displayed, then the problem is likely upstream and most likely to be one of the logic boards (TCON, Mainboard) and not the Panel/TCP/Driver IC assembly. This is a great forum. So many helpfull people.
            Not quite. Consider the T-con as "part" of the LCD. It controls the addressing of the pixels. It doesn't know what an OSD is, it just tells the LCD panel to display this or that given data from the main board. The panel could still be faulty. The good news is, there is a fix when the panels go bad. It works sometimes, it involves applying a bit of tape and pressure to the connectors, but it's not always a permanent fix.
            The main board could still be faulty, but I would say it is less likely.
            • agbayh
              • Sep 2011
              • 6
              Now, I understand the "shimming" quick fix for some issues with lcd lines. However if the problem is due to an intermittent connection, I would suspect that it would always be the same lines that are affected. Thanks for the susggestion though. I still like the fix suggested on one of the youtube videos. THe guy used a bat and tapped on top of the tv until the lines disappeard. If I had to do that, I would take a bat and take a full swing right in the middle of the panel.
                It depends on the design of the panel, but different lines may be indicative of a T-con fault not a panel fault, as yes you are correct panel faults usually affect certain lines or the whole display.
                Before you do decide to smash it, sell it to someone who can repair it.
                • agbayh
                  • Sep 2011
                  • 6
                  Unless this turns out to be an unrepairable panel, I will repair it and document what I did and share my findings. Recycling is OK but I like reusing/repurposing so much more. Plus this is going to be my guinea pig project on electronic repair. Had been a software guy most of my life. It's time to really work on the fun stuff. I'll Keep you guys posted on my Adventure with this TV. I'm sure I'll have questions along the way as I dig through the anals of circuit analysis. From what I've seen on this forum, there is not a shortage of experts in the field.
                  • Karl D.
                    • Mar 2012
                    New to this forum but have a similar problem with my 2 year old Samsung 46" LED/LCD. It has vertical colored lines. Bright ones follow the text on the screen and faint ones are on other screen areas. Other parts of the screen look fine. Please see attached pictures. Is this fixable? Is it the Tcon?
                    Really like the TV but phone quotes for repair (they haven't seen the TV) are $600-$800. I would buy a new one for that. Hate to throw this one away. Any help for DIY repair would be appreciated
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      What is the exact model number?
                      Is it the Tcon?
                      What happens to the display if you bring up the TV setup menu?
                      --- begin sig file ---
                      --- end sig file ---
                        It happens sometime in the left side, then the right side. I would try reseating the ribbon cables between the T-CON and the LCD panel first. This kind of problem is hard to be 100% sure, I would spend the money on the least expensive board first.
                        See the examples of what I have found and the fixes are.
                        • anmol
                          • Mar 2012
                          • 73
                          • India
                          @ budm,
                          Thanks for nice info.
                          wbr
                          • Karl D.
                            • Mar 2012
                            model is UN46B6000VFXZA, Version SQ01
                            Still see the vertical lines. Samsung had me reset to factory settings but no change. It is out of warrantee so Samsung could not do any more.
                              @anmol, if you want to see more pictures of failed TV's & Monitors, go here:
                              http://s807.photobucket.com/profile/budm
                              • Nocta
                                • Mar 2012
                                • 117
                                • Argentina
                                Make pressure where you have the lines. If it corrects, then the problem are the contacts.
                                I fixed some monitors by adding styrofoam to make the pressure.
                                • uberplasma
                                  • Oct 2011
                                  • 85
                                  To: Karl D
                                  OMFG!!! Craig Chaquico from Jefferson Starship - Dig the Hair !!!!
                                  But on a serious note, that fireplace, is it used? may be causing some thermal issues like warping or "drying out" of connectors, or even causing them to shift, even if it is not searing heat, the cumulative effect of the heat over time can cause problems that may not show on the bezel.
                                  • justlock
                                    • Oct 2012
                                    • 3
                                    have the exact same problem that @agbayh has in original post photo with a samsung. Already replaced the TCON, same issue. was there a final verdict?
                                    • human_fly
                                      • Dec 2012
                                      • Sweden
                                      Trying to pick up a dead thread here...
                                      I have the same problem with the vertical lines, not fixed.
                                      I have tried putting pressure to the captators. Tried cleaning and reconnecting the cables between the main and t-con board.
                                      Is the next step to order a new T-con board and if that doesn't work put the TV back where I found it; the dumpster?
                                      Anyone found a solution to this?
                                      • drpj23
                                        • May 2012
                                        • 528
                                        If putting pressure on the tab bonds did not work then if cheap enough, yes try a TCON board.
                                        Though, I would also clean the flex cables from the TCON to the panel.
                                        If all else fails, you could sell the boards either on ebay or here.
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
                                        • polaro
                                          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                          by polaro
                                          Greetings,
                                          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                          08-27-2022, 08:46 AM
                                          09-07-2024, 05:50 AM
                                        • Anonmis
                                          Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                                          by Anonmis
                                          Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                                          The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                                          12-01-2023, 04:31 PM
