Vizio VX42L, single bad CAP causeing issues?
  • Angry
    • Oct 2011
    • 5
    I recently came across a Vizio VX42L for free, and when I plug it in the logo on the from turns on to orange. When turning it on, the Vizio logo turns white and the TV screen will "blip" on just enough for the channel number to be seen. After that it just sits and you will only get that far if the TV has been sitting unplugged.
    I took it apart and pulled the PSU after reading about bad caps on the PSU.
    Of all the caps on the PSU, the only one I can find swollen is one thats right behind CN2 plug at the top:
    It possible the one bad cap is causing the issue?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VX42L, single bad CAP causeing issues?
    1) We prefer pictures hosted here on this site and not inline for a number of reasons.
    2) That is a United Chemi-con cap (brown color sleeve with a "crown" symbol). If the markings on it say KZG, that series of caps is problematic. KZG caps are more commonly found on computer motherboards and they do not survive in heat. So if the TV runs hot, the caps dry out and/or bloat.
    3) Yes, one cap could cause the entire TV not to work. Replace it with something like a Panasonic FR or FM "low ESR" series cap found at digikey or mouser. Do not use a cap from Radio Shack or Frys as a replacement.
    4) If the other United Chemi-con caps in the same area are KZG, I suggest replacing them as a preventative measure. Caps are relatively inexpensive - like around 60 to 75 cents each. Consider that you may get a working 42 inch TV for under $5 by replacing those caps.
    --- begin sig file ---
    --- end sig file ---
      ^I've seen more bloated KZG on motherboards than any other capacitor. I guess Chemi-con missed the mark as most of their other capacitors are good.
      I did the same thing, I found a 42" LG LCD TV in the dump, so I replaced four capacitors and it's been working ever since.
      Regulator U33 on the motherboard can also prove troublesome (logo will go from orange to white, but no picture appears), although as you are briefly seeing an image I doubt it is the problem.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Have to agree on United Chemi-Con KZG - a couple days ago i replaced three bloaters on a LGA775 ASUS motherboard with KZEs and the board runs like new.
        A working TV? How boring!
        • Angry
          • Oct 2011
          • 5
          Appreciate the info guys.
          Well, Ive been unable to locate a 330uf cap or anything within 20% of it locally. Going to have to order it.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            You can use a 470 as long as it's low ESR too... but definitely order a bunch if all they sell in your area is general purpose ones.
            As for how to ask, well if they can't give specific info about the part they sell, like a datasheet or a catalog listing, they're definitely generic caps and you should stay away.
            • Angry
              • Oct 2011
              • 5
              The closest thing I found at a local Radio Shack was a 470uf 32v. What I need is 330uf 32v.
              And it being a Radio Shack, I doubt they have any more info on it.
              • Angry
                • Oct 2011
                • 5
                Here is a somewhat better picture of the cap. Markings on it say "KY" After the crown symbol.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Stop screwing around!!! You have been given good advice. By now you could have identified all of the UCC KZG caps and place an order for Panasonic FMs with Digikey. The order would ship Monday, and be in your hands on Wednesday.
                  PlainBill
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • ChillingCicada
                    Vizio VO42L Issues: Need Guidance
                    by ChillingCicada
                    We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
                    Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
                    I also...
                    06-09-2021, 05:47 PM
                  • howardc64
                    Vizio SmartCast TV software bug that looks like hardware
                    by howardc64
                    Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                    It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                    11-16-2024, 05:17 PM
