HP PL4260N/HP PL5060N Plasma Screen Problems Black Blob
  • Jaymzway
    • Oct 2011
    • 15
    Here's a picture of the tv I drew the light blue line to show where the tv starts the black blob when first turning the tv on after on for awhile it seems to clear up some and after using the white wash program it brightens it up better but the color of the tv looks crappy, Any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: HP PL4260N/HP PL5060N Plasma Screen Problems Black Blob
    Check this thread. Also, use the search function; there seem to be a number of threads on this TV.
    PlainBill
      The black blob is probably a Z-sustain problem. *Usually* the whole display is affected but if the timings go bad, varying areas of the display can be affected... That is of what happened with one plasma I repaired (varying brightness across screen, some dark patches etc.)
      • Jaymzway
        • Oct 2011
        • 15
        PlainBill
        Thank you sir I have done so before asking
        However I'am cross info with everyone to see if someone had a direct hit on what this could be
        • Jaymzway
          • Oct 2011
          • 15
          Thank you sir
          Does this seem to be a fixable Deal or not worth time and effort
            Originally posted by Jaymzway
            Thank you sir
            It's viable to fix, if you can find the Z-sustain at a reasonable price.
            • Jaymzway
              • Oct 2011
              • 15
              thank you sir I think just one last question would rap this up
              how much do you think this should run me like a $100 or so?
              I really do appreciate all the help given
              jaymz
                jaymz
                It depends on the model some Z-sus boards are ÂŁ10 others are ÂŁ200. You will need to take your set apart and record the model numbers.
                • Jaymzway
                  • Oct 2011
                  • 15
                  Okay cool bro thanks for your help
                  sounds satisfying enough everyone thank you for your help I will post later to show my results on my repairs. I will bring back pictures as well
                  everyone have a great day
                  jaymz
                  • Paulcrusan
                    • Jan 2012
                    • 3
                    Just wondering if you ever got around to replacing the zsus board? If so did this resolve the issue? I am asking because I have the same TV with an almost identical problem (mines across the whole screen but gets lesser the longer the TV runs).
                      If recovers after a long period of time, 99% of the time it's the Z-sustain. If it doesn't recover, it *could* be a panel problem, which is unrepairable (at least, it's not economical to do so.)
                      • Paulcrusan
                        • Jan 2012
                        • 3
                        The economical aspect is of course is the biggest factor which is why Im trying to get it right the first time; because I am not sure how much money I'm willing to drop into the TV. The screen looks very similar to Jamzway's except the black portions reduces the longer the TV stays on, and once the TV is warm the black "blobs" only happen when the picture changes a lot. Also the color is off (awkward tint) similar to Jamzway's as well. My question is: if as the TV warms-up the "blobs" lessen, does do still point the finger at the Z sustain board? Or are there any other culprits that I should consider?
                        • Paulcrusan
                          • Jan 2012
                          • 3
                          oh never mind, i didnt read tom66's post well
                          Sorry
                          • Jaymzway
                            • Oct 2011
                            • 15
                            hey sorry it seem to take along time to find this site again
                            but i still have the tv no havent tried anything yet money has been the main issue sorry for the late reply thanks to a virus that crashed my system
                            • iparktur
                              • Feb 2014
                              Hi everyone !
                              HP PL5060N - I bought (second hand) plasma TV HP PL5060N.
                              When I switch TV on, there is an initialization to a conclusion of a trade mark HP, and the normal job with a picture of excellent quality begins. Approximately in 10 - 15 minutes, flares start to appear on the screen. After that screen becomes bright (white) and turns off, but still hear the sound perfectly.
                              For the control I have connected other TV as the monitor to the plasma TV HP PL5060N output. This screen testing TV did not turn off and any flares could not be seen on it.
                              I turn off plasma TV HP PL5060N literally on 5 -10 seconds and again I have to switch it on. TV starts to work as if you just turn it on, there is an initialization to a conclusion of a trade mark HP, and a picture of an excellent quality shows on, but approximately in 5 - 10 minutes same flare occurs and the screen turns off.
                              I opened a back cover of this plasma TV HP PL5060N. There are no external damages of the elements to be found.
                              Power Set - SONY APS-219; E135516; 1-868-783-12; EP- (GW+LP).
                              V +5V
                              +VA +60V
                              +VS +195V
                              When the screen turns off, the voltage (+VS) decreases from 195V to 95V.
                              I have tried a little to reduce +VS voltage from 195V to 180 V. The working time of the TV has increased, but still it turns off in a manner it used to do before.
                              How is it possible to find out:
                              1 - the voltage (+VS) falls from 195V to 95V as a result of unstable job Power Set
                              OR
                              2 - the voltage (+VS) falls from 195V to 95V as a result of capacity increase in any out board (ZSUS OR YSUS board) or in plasma panel itself (screen PDP)?
                              Can someone suggest how to remove this problem ?
                              • jean luc ferre
                                laptop hp g72 b52sf screen problems
                                by jean luc ferre
                                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                06-07-2025, 03:27 PM
                              • Hondaman
                                USB problems?
                                by Hondaman
                                Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                08-12-2024, 03:26 PM
                              • clabr
                                Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                by clabr
                                Need help to solve some problems with this laptop.
                                After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                Before this had happened I observed some other problems:
                                When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                12-02-2021, 08:09 AM
                              • ArMaaN376
                                Samsung PS51E550 Plasma TV
                                by ArMaaN376
                                I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                Opened TV cover & observed foll
                                a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                How to confirm Y -Buffer board...
                                06-19-2024, 04:05 AM
                              • jm1234
                                Panasonic plasma TX-P42ST50 - 6 blinks
                                by jm1234
                                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                I checked that board for any obvious faults...
                                05-22-2024, 06:59 AM
