Cap selection for San Ji board in Blu:Sens TDT/ DVD
  • Boris
    • Nov 2010
    Hi folks... I was given some spot on advice about a year ago in these forums- and to my amazement, I sucessfully repaired my Samsung monitor by replacing three caps. It was my first try and I think my soldering was pretty poor... but it works!
    Now I have what looks to be an easier job, but I am seeking advice about which caps to purchase (from RS-Online).
    What I want to do is replace some very suspect looking caps on a little board inside my (undeniably cheap) Blu:Sens TDT/DVD unit. Without this I have no telly: which means an unhappy baby in the house!
    Anyway the board seems to be made by San Ji Electronics and has various numbers on it including 2005/10/14, GL-001-A1, 94V-0 and E168172. Probably the board itself isn't that important as it's the caps I need to replace.
    They seem to be aluminium through hole types. One says 400v 22μF plus SW CD110 is 20mm high approx 12mm dia and the other 10v 2200μF SW CD288 20mm high approx 9mm dia I'm fairly sure the capacitance reads μF not uF but the tail on the left is very short (pretty much the same as the tail on the right).
    I'm not experienced in these things, obviously.. and looking at the options available on the RS-Online site I have no idea which Ripple Current I should choose- they have a wide range of mA options.
    Advice would be great please...
  • Boris
    • Nov 2010
    Re: Cap selection for San Ji board in Blu:Sens TDT/ DVD
    Hmmm I forgot to include the physical dimensions in my product selection on RS... and once I do I get only one option.. with 760mA ripple current, for the first cap. Would that be ok? http://uk.rs-online.com/web/p/products/7152296/
    For the second there are a few options with the dimensions I need, with various Ripple current ratings.. http://uk.rs-online.com/web/c/passiv...uct%20Diameter
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • jimbodriver
      Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
      by jimbodriver
      I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
      Initial results:
      Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
      03-20-2022, 02:30 PM
    • repair-it
      Need advice testing a samsung power supply board with scope
      by repair-it
      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
      07-12-2025, 11:00 AM
