Vizio Plasma TV JV50P
  • dsinatore
    • Oct 2011
    Hello Everyone. New to this site but found it very useful in diagnosing my original problem. I have a 5 YO Vizio plasma TV JV50P HDTV10A. I was having trouble with it for about 4 months. The first thing in the morning the unit would give the Vizio trumpet call, burr/burr and not come on. The sound on the wireless rear sparkers would work. Wait about a minute and turn it off, then on and the picture would work fine for the rest of the day. Then last month, the unit was taking almost 15 minutes to come on. Then on day, it would only give the trumpet sound and would not come on. After searching this site and others, I took off the back to see if I could see the blown caps. There were several on the PS board. So I purchased a board from an ebay seller. Board came in 2 days, looked great. I installed in and turned on the TV. To my surprise, no trumpet sound, but also no picture. sound works now out of the front speakers normally, but there is absolutely no picture, no menu, no indication that the panel is trying to turn on.
    What is strange is that it worked with the trumpet sound for some time. But would always come on. Now with the new PS board nothing.
    Another stance thing, they state on the back that Va = 58v and Vs= 192v. I could not get these readings on my meter. Possible problem?
    Another thing I noticed there are 4 LEDs on the inverter board. 3 come on at power up. They are labeled D2, D3, D4 D5. 3,4,5 come on at power up then 3 goes out. D2 never comes on. Is this a problem?
    A lot of information here and hopefully I explained all the symptoms that I have. I am not a board guy, but I kind of know my way around things. Hopefully I didn't waste my money on a new PS board. Plasma's only cost $500 and I already spent $100.
    Dino
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio Plasma TV JV50P
    To replace the bad caps, it would have probably cost you less than $20 USD + shipping (if you are in USA) in caps from digikey (you get it in 48 hours). Desolder the old ones and solder in the new ones. By replacing the caps on your original PS, you are guaranteed to get quality brand name caps.
    Your replacement PS might also have bad caps as well (just not bloated). Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      Dino
      Retiredcaps has covered most of the points; here's a few suggestions.
      1. Doublecheck the power output connectors; make sure they are positioned properly.
      2. Remove the new power supply and reinstall the old. Verify you get the proper readings for Va and Vs. If you do, contact the seller and RMA it.
      3. It's a detail - plasma TVs don't have inverters.
      PlainBill
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • howardc64
        Vizio SmartCast TV software bug that looks like hardware
        by howardc64
        Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
        It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
        11-16-2024, 05:17 PM
