chimei cmv221d bright whie screen
  • phill5252
    • 8
    Hi Guys
    Im new at this,
    is there any better caps than others to buy please. I have a board with Capxon brand on them and the board is giving me headaches
    Its a Delta Electronics DAC-19m009 from a chimei cmv221d exhibiting a bright wite screen.
    Thanks Phill
  • retiredcaps
    • Apr 2010
    • 9271
    Re: chimei cmv221d bright whie screen
    A bright white screen could mean that the cable between the logic board and the lcd panel is disconnected and needs reseating.
    --- begin sig file ---
    --- end sig file ---
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
