proscan 40" 40ld45q...picture issues
+ More Options
Posts
  • virginiahale
    • Sep 2011
    i have this tv..i had a fire at my apartment but the room the tv was in had little to no damage...i did notice on the tv when i cleaned that it was a lot of soot however...now the tv shows extremely bright and adjusting the "bright control" does not help also around the peremiter theres like a halo....does anyone know whats going on and what if anything i can do? HELP!!!
    Re: proscan 40" 40ld45q...picture issues
    Fire damage is a very tricky thing. The soot may be conductive and be interfering with the operation of the inverter. The first thing would be to try to claim on an insurance policy. If that fails, take the TV apart, and give it a very good clean. I suggest bathing all of the components in warm soapy water and allowing them to dry for 24 hours before replacing them in the TV. Also, heat (even just 50-60 degrees C) can damage an LCD panel.
    • virginiahale
      • Sep 2011
      thanks tom66...unfortunately NO INSURANCE at that time...i will try the bathing of the components..sometimes it seems that the picture is getting a lil better than when i first plugged it up...at least i can make out the picture now
      • Schwoin
        Philips 243v5lhsb00 Monitor Picture too bright
        by Schwoin
        Hey everyone,
        the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
        While i tried to tilt the screen a little bit while it was displaying a picture, iยดve noticed, that there appeared some purple pixels. In the following picture
        you can see them on the top half of the photo.
        At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
        03-21-2023, 12:40 PM
      • SoulFreeze
        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
        by SoulFreeze
        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
        After repairing the above issue, I realized the following remaining problem,
        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
        The computer recognizes headphones are connected and displays a popup in windows
        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
        06-21-2025, 09:53 AM
      • Nagyesz
        Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
        by Nagyesz
        I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
        All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
        How can I extend its lifespan? Could reflow help?
        It has ryzen 5 5500h, rtx 2050, no soldered ram.
        Example of the artifacts:
        03-01-2025, 11:11 AM
      • pwnjuice
        Bitlocker issues
        by pwnjuice
        Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
        Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
        Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
        01-06-2025, 05:33 PM
      • Skgod
        Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
        by Skgod
        Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
        Black screen, freeze
        The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
        When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
        So can anyone tell me what would be the possible cause?...
        10-16-2024, 08:11 PM
