No Picture or Audio on Insignia NS-LCD26A
  • xelectech
    retired tech
    • Nov 2014
    • 238
    Re: No Picture or Audio on Insignia NS-LCD26A
    Well, little progress to report, just note to self :
    Amazon showed up with 20 35v470uF Nichicon caps for 8 bucks, so got enough to go back and remove the 25v rated ones I tried (didn't help)
    The 'cap by the 7legged IC' on pwr bd is C519, 50v47uF was indeed bad, reads 2uF and several ohms esr, replaced it but set is still the same, power led blinks on momentarily and goes right out...tbc
    • wukong543
      • Aug 2018
      Researched online and found this thread and read about heating up the chip under the heatsink which is under the RF shield. I discovered that between the chip and heatsink they had put a 1/8" piece of rubber foam. Really? This doesn't conduct heat worth a crap. I took a 1500w heat gun and put it about 1.5" above the chip and applied heat constantly for 2 minutes. After that I pushed down on the chip and held it down until it cooled.
      I then applied CPU thermal paste and put the heatsink directly on to the chip
      and set up the TV and turned it on without reassembling and the picture came up fine.
      So, I put the rubber foam spacer at the top of the heatsink to keep the same amount of space and tightened the two screws down on the RF shield which caused the heatsink to come up off the chip. I placed a small piece of metal on top of the rubber to keep the heatsink from coming off the chip and tightened it up and reassembled the t.v.. So far it's been running fine for the last 7 hours.
      Old thread and old t.v. but maybe someone like me still has one they want to fix.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Darren Hibbert
        MacBook A2179 Audio board+Power button boardview & schematic needed
        by Darren Hibbert
        Hi.
        Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
        There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
        Many thanks. ...
        Yesterday, 02:38 PM
      • grimacelord
        MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
        by grimacelord
        I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
        12-11-2023, 11:13 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
