Lg 42" lc55 lcd
  • junger
    TV Enthusiast
    • Sep 2011
    • 13
    • England
    Lg 42" lc55 lcd
    Hi all, looking forward to my input into this forum. I am, I have at the moment having difficulty with the power board of a LG 42" LC55 LCD.
    The sympton is the LCD switches on backlight does not light,the LCD then goes back into standby
    I have replaced the PSU board and that fixed it, looking at the faulty PSU, I noticed that the large cap is bubbled at the top, any ideas please?
  • billansor
    • 85
    Re: Lg 42" lc55 lcd
    Hi
    Welcome to the forum!! This is a very informative group of people as well as very helpful! I have learned a great deal and one of the bigger things is trying to take pictures that provide a great deal of information for many of these folks. Attaching pictures is located under managing attachments.
    To answer your question, the cap with the bulge was most likely leaky / drying out hence the bulge.
    Replacing that cap may have fixed the set, but there could have been other issues as well as other bad filters.
    Hope this helped a bit... While the information is not all inclusive, it does give you an underlying answer to your question.
    Bill
    • junger
      TV Enthusiast
      • Sep 2011
      • 13
      • England
      Re: Lg 42" lc55 lcd
      Thanks for that, If you look at the photos, the PSU problem that I am aware of is going into standby and is sorted by changing the 10volt leaky electrolytic caps (see photos, before and after cap change). The fault that has stumped me is the large cap which is leaking but having changed that cap and the inverter the lamps still do not illuminate. It is the power board because I canged the power board from another LCD and the unit then worked. Any ideas please?
      • PlainBill
        • Feb 2009
        • 7034
        Re: Lg 42" lc55 lcd
        There appears to be a high voltage supply on the lower end of the board. A good quality picture of the bottom side of the board would be a big help.
        PlainBill
        • 1beertap
          • Mar 2009
          • 219
          Re: Lg 42" lc55 lcd
          Two possible things to check are a shorted inverter transformer and/or a shorted power mosfet. I've circled these in the modified photo attached.
          • 1beertap
            • Mar 2009
            • 219
            Re: Lg 42" lc55 lcd
            Agree with PlainBill, clear photos of the bottom of board would help.
            • rmoody
              Learning Member
              • Jul 2011
              • 262
              Re: Lg 42" lc55 lcd
              not too sure of your photos and previous comments. Did you change some caps already? I spotted 4 bad in the first pic. I circled them below
              • junger
                TV Enthusiast
                • Sep 2011
                • 13
                • England
                Re: Lg 37" 2500 lcd
                Hi
                Sorry, I have already changed the 10volt caps, that was to demonstrate that the 10 volt caps is not my problem (as I have done a few with that problem see cap1 jpeg which shows a replacement cap). My problem is with a LG 2500, when on analogue there are fine verticle lines down the screen when I switch to DTV, then the lines are there but no channel is shown and the set locks up. to restart the LCD it has to be disconnected from the mains and arial removed before switch on, Very strange, not come across this before. anyone know?
                I will try to post some photos later
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Lg 37" 2500 lcd
                  Originally posted by junger
                  Hi
                  Well, which is it? You opened the thread with a 42" LG TV, now you are having a problem with a 37" with a different problem?
                  PlainBill
                  • junger
                    TV Enthusiast
                    • Sep 2011
                    • 13
                    • England
                    Re: Lg 42" lc55 lcd
                    Sorry, It is a bit mixed up, I have 2 seperate faults on two seperate lcd's. I will post the correct model and the fault associated with that model.
                    Regards
                    junger
                    • junger
                      TV Enthusiast
                      • Sep 2011
                      • 13
                      • England
                      Re: Lg 42" lc55 lcd
                      Ok, 37" LG has no backlight. The symptom on test is fuse o/c.
                      The large cap is puffed up, therefore it has probably passed a/c.
                      One transistor is damaged and one power diode is damaged (shown in the photos).
                      Replaced Cap, Mosfet and Power Diode on PSU Board (from another unit) and the LCD now has a backlight, have found a supplier for the Cap and Mosfet but cannot find a supplier for the Power Diod, any ideas anyone ?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: Lg 42" lc55 lcd
                        Mouser has them in stock at $.75 each.
                        PlainBill
                        • junger
                          TV Enthusiast
                          • Sep 2011
                          • 13
                          • England
                          Re: Lg 42" lc55 lcd
                          Sorry, have been quite ill for some time, but two stents later, better now, so am back
                          regards
                          junger
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • Hakuu
                            by Hakuu
                            Hi There,
                            More Details
                            TV Model - LG OLED77G1PUA
                            07-12-2023, 02:37 PM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
                          • canadaboy25
                            Panasonic TC-P54VT25 No image. A or D board?
                            by canadaboy25
                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                            01-17-2021, 01:06 AM
