Get rid of screen sparkles in plasma TV's
  • PowerAmpFreak
    • 977
    • Sweden
    I've seen it some times, random sparkles, mainly red, with different concentration over the screen, I mean some areas may have more or less of the sparkles.
    I've also seen for example after an on screen display graphics has been shown (like an input select info square or similair) and then goes away, the area where the on screen info was has more of the sparkles and fades away in a second or two.
    May anyone explain what's causing the sparkles and if there is a way to get rid of them? I've trimmed all voltages according to the sticker on the plasma. I don't ask for a specific model, more of general info what causing this.
    I have seen that the pot on the Y-SUS (Vset) may affect the amount of sparkles but not possible to get rid of them entirely.
    Thanks for now.
  • rayrod81
    • Oct 2010
    • 205
    Re: Get rid of screen sparkles in plasma TV's
    Generally it is a control board and Y-sustain problem. The control signal is slightly out of sync with the switching capability of the components on the Y-sustain due to age and breakdown caused by heat. LG particularly has problems when the Y-sustain is replaced on the 42X3 panel and occasionally on the 50X3 panel. Their solution is to reprogram the control board while also readjusting voltage to different specs. If you do not have the Jig to reprogram the control board then they recommend replacing it entirely. I would assume that it is the same with Samsung plasmas but I am not entirely sure. I will have to look through my plasma training manuals to confirm.
    • cadillacman
      • Feb 2011
      • 524
      have seen that same issue and "fix" with lg sets as well...
      • PowerAmpFreak
        • 977
        • Sweden
        So you mean, when the Y-SUS board or it's IPM is changed the new parts doesn't have the same switching speeds as the old ones?
        So the controlboard has to be reprogrammed to compensate for this.
        I would really like to see the training manual suggesting this. Could you point towards a training manual for an LG plasma suggesting this solution?
        • rayrod81
          • Oct 2010
          • 205
          It is one of the LG training manuals on scribd that mentions reprogramming the logic board to get rid of the maldischarge. I will look for it and post the link.
          • rayrod81
            • Oct 2010
            • 205
            Here it is: http://www.scribd.com/doc/7580885/LG...raining-Manual
            It is on page 21 and 22 where it talks about the maldischarge and page 47 through 49 or 50 that goes through the process of a ROM download for the control board and the voltage adjustments needed.
            • PowerAmpFreak
              • 977
              • Sweden
              Thanks!
              • capkid
                • Oct 2010
                • 1339
                So, is the JIG the only way to flash the ROM? Are the other three software download instructions for different downloads?
                LG Plasma Mal-Discharge Correction Service
                • cadiman
                  • Mar 2010
                  • 397
                  I have run into this on L/G when changing the Z board as well. It happens with about 50% of the tvs I repair. I also noted it can be worse if not replacing with the same revision (a,b,or c) at the end of the board part number.
                  You can not adjust it out by changing va or vs. You can minimize it by adjusting the Y sus waveform a bit.
                  I think the speckles are the timing of the Y and Z boards and how they work together to form the picture.
                  This may be another reason to replace both Y and Z boards at the same time with the same revision.
                  • capkid
                    • Oct 2010
                    • 1339
                    In my case, I just replaced the IPMs on the Y and Z boards and a fuse on the Y board. I'm going to try a new controller board to see if that corrects the issue.
                    • fastvideo
                      • Dec 2008
                      • 55
                      https://www.badcaps.net/forum/showthread.php?t=10657
                      Is this the same problem we have here?
                      I still have that RCA and also a Hitachi plasma have similar problem both with LG panel, would like to see if that can be fix.
                      • capkid
                        • Oct 2010
                        • 1339
                        Yep, it's the same problem. I bought my Toshiba used, and I now know to stay away from older plasmas. If the control board replacement doesn't fix my problem, I guess I'll just part it. The snow is annoying.
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • Lintesir
                          Panasonic P42S30 Plasma - Pink sparkles
                          by Lintesir
                          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                          There is about a 5cm high region at the top without any sparkles,...
                          07-26-2024, 03:16 AM
                        • Alicat
                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                          by Alicat
                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                          Model number is TH-50PZ85U
                          Power comes on and the red power light stays on solid.
                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                          I also hear a few clicks.
                          I also think my parents said there was a thunderstorm and the TV failed after that.
                          Section 6 in the service manual talks about power and no screen,...
                          10-30-2024, 10:09 AM
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • Zelek11
                          Panasonic Plasma screen interference on left half of screen
                          by Zelek11
                          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                          10-14-2022, 04:54 PM
