vizio vx42l mystery
    vizio vx42l mystery
    Hello all,
    First of all, as a new member of this forum, I would greatly appreciate your patience and understanding, as I am not as experienced as you all, regarding these issues. With that said, lets begin. Initially my vizio ceased operation with only the amber light on, and not coming out of standby. After reading some forums regarding similar incidents to mine. I replaced the power board. Same results. Then I took out the main board and had the u33 replaced as advised in many of the forums seen here. After re-assembly, (with back cover off) I tried to power up. Nothing. Then I remembered the reset button on the main board. Tried that, then set powered up and was running as normal. After a few hours of sleep, powered down, then tried to power up again with remote, stuck in standby again. Took off back cover yet again, pushed reset button, and its back up again. Only now, it doesn't respond to remote commands and vizio light is out completely.
    Some things to know:
    both inverter boards and lcd display have already been replaced
    vizio light display already replaced
    power supply also replaced...
    Quite a mystery, any and all help will be appreciated!!
    HAAS
