Sony Bravia klv-37S400A colour problem
  • ajayigi
    • Aug 2011
    • 14
    Hello All
    I have a Sony Bravia KLV-37S400A. few days back when i turned on the tv the colour became blurred on the images and coloured
    part of images shows dark blur and some other side shows light colour blur. Am out of warrenty and used hotair as a test for any dry probs but no change.
    Any idea?? Would you suggest me that what might be the reason behind this?
    Am expecting a kind helping hand...
    By Jaymon
    I have taken many photos of the same and attaching. You can see the blur/washout colour in those screenshots.
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    Re: Sony Bravia klv-37S400A colour problem
    Is this a problem on all inputs? perhaps change to HDMI, component cable, or coax and see if the problem persist on all inputs.
    • ajayigi
      • Aug 2011
      • 14
      Hi rmoody, Thanx for your reply.
      Yes, this is a problem on all inputs.If we connect any mode the picture will be like this.
      Still get confused about which area would be the exact place to check n find.
      Thanx again
      Jaymon.
        Try fiddling with the LVDS cable. This is the connector which goes from the main processor board (with all the inputs) to the LCD panel or TCON board, which sits on the LCD panel.
        • ajayigi
          • Aug 2011
          • 14
          hi tom, thanx for ur reply.
          Yes, at first i tried the same too but no change.
          Thanx again,
          Jaymon
          • Village Electronics
            OldPro
            • 118
            Thanx again,
            Jaymon
            I think the panel is bad.
            • hoadle
              • Jul 2010
              • 174
              I'm very sure the LCD panel bad
              • cadillacman
                • Feb 2011
                • 524
                im on the fence too..
                could try a tcon board, but nowing sonys long history with shitty panels in bravias, its prolly in the panel.
                • ajayigi
                  • Aug 2011
                  • 14
                  Hi friends, thanx for your valuable advices. Yes, let me check with the T-con board and all then i will surely post the reply.
                  Thanx again,
                  Jaymon
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Here's a document on troubleshooting tcon and panel failures.
                    PlainBill
                    • anihilistabroad
                      • Sep 2017
                      • New Zealand
                      Thanx again,
                      Jaymon
                      Hey Jaymon,
                      Did you end up replacing the T-Con board? I've been conned into buying a broken TV, did you ever get your TV to work?
                      Danny
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4364
                        • Italy - Milan
                        almost surely is the tcon board (gamma chip like as15-as19)
                        • noledud
                          • Dec 2013
                          • 413
                          • united kingdom
                          faulty chip can be replaced
                          If you cant do it yourself there are AS15 repair services on ebay
                          • PopsCaps
                            Sony Bravia KDL-40V2500 that will not power on
                            by PopsCaps
                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                            I do not hear any sound and I cannot see any backlight.
                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                            03-25-2025, 11:23 AM
                          • justin35
                            Sony bravia kdl-43w755c - boot loop
                            by justin35
                            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                            from what i read online it looks to be an emmc issue…
                            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                            i took out the board and say an samsung 16gb emmc
                            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                            i could try to put one instead of the 16gb one, but will it work?
                            where do i get the software from?
                            any help will be much appreciated!...
                            03-06-2024, 12:26 PM
                            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                            10-16-2024, 05:15 AM
                          • Spc.
                            Sony Bravia KD43XF7596BAEP - Android no picture
                            by Spc.
                            Greetings everyone.
                            I also have Sony Bravia, model:
                            Sony Bravia KD43XF7596BAEP - Android.
                            What happend is that image dissapeared while we were watching tv.
                            Diagnostics:
                            1. TV turns on, no errors
                            2. Backlight turs on, no errors
                            3. Power indicator turns on, white color, no errors
                            4. Menu works on android, you can hear sound while switching channels
                            5. Volume up and down works via TV remote and via buttons
                            6. Tunner works, HEVC / MPEG-4 decoder works
                            7. I get audio from channels
                            8. No picture is present,...
                            05-19-2022, 04:28 AM
                          • KYBOSH
                            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                            by KYBOSH
                            Previous owner said TV just went blank one day.
                            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                            I just downloaded the Sony KD-75X7800F Service Manual and...
                            11-19-2024, 10:12 AM
