More Vizio VW42L Problems - HELP PLEASE!!!
+ More Options
Posts
  • etorg1125
    • Jul 2011
    • 3
    I have a vizio vw42l that I got for free. The guy I got it from said he heard a loud "zap" noise then the screen went black. When the power button is pressed the unit comes on for about 2 seconds then goes black again. I am somewhat of a hack and removed the back cover and visually inspected all of the readily accesible boards and could find nothing obviously wrong. One interesting side note. I powered the unit on with the inverter boards ungrounded and the unit came on and stayed on with a flickering picture. As soon as I grounded either one of the inverters the screen went black again.
    What should check and/or replace?
    Thanks in advance for your advice....
  • cadillacman
    • Feb 2011
    • 524
    Re: More Vizio VW42L Problems - HELP PLEASE!!!
    sounds like inverter or ccfl issues.
    If take a meter and make sure you have good power to the inverter board.
    • etorg1125
      • Jul 2011
      • 3
      What pins should I test specifically and what voltages am I looking for?
      Thank you again...
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        There are lots of threads here with this model number. The first thing I'd do is research the known problems and solutions of this set. Just go to search and put in the model number.
        • 70JUDGE
          • Jul 2010
          • 81
          I would have to say your problem is one,or both of the inverters.If you look at the part numbers on each inverter,and they are the following,I would either repair,or replace them,and this should fix your TV.Master LG 6632L-0448A Slave LG 6632L-0449A What usually goes wrong is the one,or more of the following,the two capacitors,the IC chip,and the four transistors.I would try replacing the capacitors first.If that doesn't work,and you can't,or don't have the equipment to change the IC,and,or transistors,I would replace the master inverter before the slave.I hope this helps.Thank You very much!
          Tyler
          • etorg1125
            • Jul 2011
            • 3
            Tyler. Thank you very much for your response. There is nothing obviously wrong with the inverter boards so I think I am just going to replace them both. I read something that boards should be purchased as a set to insure compatibility. Is that a true statement?
            And to Dgtech.... I already read all of the forum posts about my set before I posted a question. None of the answers fit my problem....
            • howardc64
              Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
              by howardc64
              Failure Symptom
              No Display. Just random blocks of grouped vertical red lines.
              Disconnect right 1/2 panel (rear view), left 1/2 displays properly
              Masking T-Con Signal Diagnostic
              Reduced masking to 5 signals on right 1/2 panel and get perfect picture
              Pins are
              1 GND
              2 VGHD
              3 XON
              4 VSSQ
              5 LC2
              6 LC1
              VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
              Pictures and Schematic
              XON, LC2, LC1 are on AUO s302-21 32pin QFN...
              10-14-2024, 01:30 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • ngml
              Repair of an LG split AC system indoor unit PCB
              by ngml
              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
              This indicates an error in the communication between the outdoor and the indoor unit.
              The outdoor unit is fine, so the problem is the indoor PCB.
              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
              Does anybody have the schematics of this board,...
              02-01-2025, 12:55 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
