Sanyo CE37FD47 LCD No Power
  • Liam.25
    • Feb 2011
    • 107
    • Uk
    #41
    Re: Sanyo CE37FD47 LCD No Power
    plain bill - im assumning you know that nothing was ever tested with those settings in post 18?
    that picture was simply just so that dumpystig can answer my question.
    • dumpystig
      • Jul 2011
      • 485
      You got new meter now?
      System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
      • Liam.25
        • Feb 2011
        • 107
        • Uk
        #43
        not yet mate, will have soon, just waiting for girlfriend, shes going to take me.
        • dumpystig
          • Jul 2011
          • 485
          Ok, catch you later. I'm off back to trying to sort my own set, been ongoing for 3 weeks now but I'm determined to fix the bastard (hopefully without any cash outlay - although my labour up to now would be running into several hundred quid haha!).
          • Liam.25
            • Feb 2011
            • 107
            • Uk
            #45
            ok. good luck. catch ya later
            • PlainBill
              • Feb 2009
              • 7034
              Originally posted by dumpystig
              Ah, how are you today, good I trust?
              Yes, as you can see we have had a bit of a struggle today... but Liam.25.beta will be returning I'm sure, after first reading the manual for his new DMM
              I'm sure most of us have had a similar experience. My first VOM was obtained by repairing one damaged when my boss tried to measure the 120 VAC with the VOM set to a resistance scale. Some years later I blew that one up when I found a cracked focus voltage divider.
              PlainBill
              • PlainBill
                • Feb 2009
                • 7034
                I believe you. But there is a good reason you NEVER leave the meter leads in that configuration. I USUALLY set the range before grabbing the probes. I very rarely use the 10A range, so I NEVER check that the probes are plugged into the correct jacks. It could come back to bite me.
                I would also be nervous owning a meter that can't tolerate 330 VDC.
                PlainBill
                • dumpystig
                  • Jul 2011
                  • 485
                  Liam, did you get your new DMM? Where you up to with your set now?
                  • Liam.25
                    • Feb 2011
                    • 107
                    • Uk
                    #49
                    Hi dumpystig, testing now, same as before and im getting 249volts.
                    so its clear the board is getting power, but powers not traveling right to main outlet??
                    • dumpystig
                      • Jul 2011
                      • 485
                      I'm not sure where you are testing - can you explain more.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        I have labeled some parts of the power supply.
                        Since you appear to have voltage across the main filter cap, let's perform a leap and check voltages from the standby supply.
                        The only cable you need connected at this time is the AC input cable in the lower right corner. Turn the power supply upside down and measure the voltage across the three caps I have labeled 'Standby Filter Caps'. I would expect voltages in the 5V -15V range. If you get no voltage across any of those three caps, the standby supply is dead.
                        I have labeled an IC Standby SMPS Controller. What is the part number on that IC?
                        PlainBill
                        • Liam.25
                          • Feb 2011
                          • 107
                          • Uk
                          #52
                          Hi Bill, no voltage reading on all 3 of the standby filter caps.
                          the IC is labeled "DL321 VK08".
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Excellent!!! That IC is a Fairchild FSDL321L. It's a low power all in one SMPS controller and power FET. The datasheet link is here.
                            In the picture, pin 1 is in the upper left corner. With the power supply connected only to AC power, what are the voltages on pins 2, 3, 4, and 5? Do NOT attempt to measure the voltage on pins 6, 7, and 8; it could damage your meter.
                            PlainBill
                            • Liam.25
                              • Feb 2011
                              • 107
                              • Uk
                              #54
                              0 voltage on pins 2, 3, 4 and 5?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Pins 6,7,8 are the drive for the SMPS transformer. Measure the voltage from pin 1 to pin 8 of the SMPS controller. This SHOULD be about 249 volts.
                                PlainBill
                                • dumpystig
                                  • Jul 2011
                                  • 485
                                  No updates then...?
                                  • Liam.25
                                    • Feb 2011
                                    • 107
                                    • Uk
                                    #57
                                    Time was of an essence and i purchased a new board, still got the old board here.
                                    Bill asked me to measure the voltage from pin 1 to pin 8 of the SMPS controller, did he mean measure each of the 8 pins?
                                    there quite diifficult to see as there underneath the controller. also got my 3 rd multimeter now, its an half decent martindale, very happy with it.
                                    • dumpystig
                                      • Jul 2011
                                      • 485
                                      No he means put Black probe to Pin1 (GND) and Red probe to Pin8 (Drain) and post the result.
                                      Yeah, Martindale is a good brand, you should be fine with that.
                                      • dumpystig
                                        • Jul 2011
                                        • 485
                                        So is your set working now with the new board installed?
                                        • Liam.25
                                          • Feb 2011
                                          • 107
                                          • Uk
                                          #60
                                          yes all fixed with a new/used board.
                                          but i still would like to know what was wrong all three boards i still have here.
                                          its been good with all of your help. i learn fast, i have a passion for electronics. im 26 and have studied computing for 11 years. im an it technician and recently turned to component level in pcb.
                                          so expect to see me around these forums.
                                          thanks again for everybodys help.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            09-06-2024, 05:59 AM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
