Panasonic TH-42PZ8BA help!
  • netdent
    • May 2011
    • 208
    Need some help with this one, first panasonic I have opened up! it powers on as it should to steady green light but screen is blank, have measured 203volts to both sus boards and checked the psu fuses I'm stuck now, not tried to connect video to see if sound present due to no dvd spare to try but will need to find one, any help welcome
    P.s green led lit on each y and z sus
    sigpic
  • PlainBill
    • Feb 2009
    • 7034
    Re: Panasonic TH-42PZ8BA help!
    Good quality pictures. A couple of things you might want to check: In the lower left corner, between the two transformers and to the left of the orange capacitor, it looks like a dead worm is wrapped around ??? Above the upper of the transformers, near the top of the board, the white rectangular ?resistor? looks like it might have been dislodged.
    PlainBill
    • netdent
      • May 2011
      • 208
      Hi Bill, yes the worm is actually a bead of silicone type stuff! I noticed the resistor too but it is securely soldered.
      thanks Ronnie
      sigpic
      • netdent
        • May 2011
        • 208
        This one is back on my bench before I decide to strip it for parts! can anyone help please
        thanks Ronnie
        sigpic
        • netdent
          • May 2011
          • 208
          Just to update, the screen does light to dull luminance no sign of menu etc
          sigpic
          • rayrod81
            • Oct 2010
            • 205
            This points to a problem with the D-board. The fact that the LEDs on the SC and SS boards are lit mean that they are most likely working properly.
            • netdent
              • May 2011
              • 208
              Thankyou for the reply, not sure which is the D board sorry, is this the main av board or the psu, I suspect the av board, if I unplug the ldvs cable to the main board I get a full white screen
              thanks Ronnie
              sigpic
              • rayrod81
                • Oct 2010
                • 205
                The D-board is the control board of the plasma. It should be behind the cage that houses the main board or av board.
                • netdent
                  • May 2011
                  • 208
                  Ok great thankyou, is there a sure way to verify as faulty ie status led etc, just want to be sure before looking for a replacement
                  thanks Ronnie
                  sigpic
                  • netdent
                    • May 2011
                    • 208
                    just a thought! if the control board was at fault I should get sound if I feed a video signal?
                    sigpic
                    • rayrod81
                      • Oct 2010
                      • 205
                      No way to test it that I know of. There should be a troubleshooting diagram for no picture in the service manual for this generation of plasma. You can find it at elektrotanya.com. Search for the TH-42PZ80U it is the same chassis and parts as the TH-42PZ8B. Make sure you download the service manual for that TV and not the training manual for the entire PZ8xx series. I have run across this problem a couple of times in the past and the D-board was the problem.
                      • rayrod81
                        • Oct 2010
                        • 205
                        Not sure on the sound. I would think so but can't be sure.
                        • netdent
                          • May 2011
                          • 208
                          Thankyou rayrod81 I will look into it and see what I can find, be nice to get this working has been on the pile a long time
                          thanks Ronnie
                          sigpic
                          • netdent
                            • May 2011
                            • 208
                            Ok the flow chart points to the D board, thanks for the advice, will order and report back
                            Ronnie
                            sigpic
                              That's a weird PSU, I've been trying to figure it out. I don't see any diodes for the secondary output, anywhere... and I see a lot of holes where diodes could go. Also, no PFC stuff but places for them. Has someone decided to remove all these components?
                              • rayrod81
                                • Oct 2010
                                • 205
                                Most of the components on these Panasonic PSUs are soldered in from underneath and attached to the large metal shield that also acts as a heat sink.
                                • netdent
                                  • May 2011
                                  • 208
                                  just another thought guys if I scart this set to another set should I get the panasonic screen
                                  sigpic
                                  • netdent
                                    • May 2011
                                    • 208
                                    The control board is ordered, was unable to get any audio connecting a dvd player but its difficult to know the tv is on correct channel? also tried scarting to another set but still no joy, bit of a gamble just hope the part cures the fault
                                    Ronnie
                                    sigpic
                                    • netdent
                                      • May 2011
                                      • 208
                                      Ok the D board came this morning, still not working!!! my gut instinct was av board? question is do I now order this or cut my losses?
                                      cheers Ronnie
                                      sigpic
                                      • jimjoe123
                                        LCD TV Green/Pink screen problem
                                        by jimjoe123
                                        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                        Then each time...
                                        02-23-2020, 01:29 AM
                                      • fixxy88
                                        Panasonic 55DX600u repair help - no display fast green then slow red led flash
                                        by fixxy88
                                        Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
                                        Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ...
                                        02-22-2023, 09:14 PM
                                      • ItepK
                                        Panasonic TX-P42G30E green light blinking, no video, no audio
                                        by ItepK
                                        Hey everyone!
                                        I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                        This post describes my entire troubleshooting process of this TV.
                                        When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                        I've taken the unit apart, and I've started to check some voltages:
                                        • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                        12-22-2023, 05:06 AM
                                        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        09-12-2024, 02:00 PM
                                        Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook Vero Specification for Upgrade or Repair
                                        This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...
                                        09-07-2024, 03:10 AM
