Vizio VW42L HDTV10A no picture or sound
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    Re: Vizio VW42L HDTV10A no picture or sound
    The service manual MIGHT be wrong, you might be making a mistake (yes, it happens), or there might be a bad component.
    The usual design has a series of regulators. The main power supply puts out 5 V nominal (it often is .1 or .2 volts higher). The first LDO regulator drops it to 3.3 volts for the processors. The 3.3 Volts also is the supply for the 2.5 volt regulator, which in turn supplies the 1.8 volt regulator. When I see a regulator whose input voltage is too high I look for the regulator that is supplying too high a voltage.
    PlainBill
    The best i can tell the U4 power only comes from the pinout from the powersupply and only goes through 1 capacitor. Shouldn't U4 be showing an output too? or will the higher voltage not allow any output
    • PlainBill
      • Feb 2009
      • 7034
      Without seeing the schematic, I can't be sure, but in general I would say U4 is defective.
      ???? When I looked at the pucture you provided, I saw U4 was missing; I assumed you had removed it. Looking at the other pictures in the thread, U4 is missing in them, too.
      PlainBill
      • rmoody
        Learning Member
        • Jul 2011
        • 262
        PlainBill
        yeah i know it's weird, very weird. I thought maybe it was on the bottom so i pulled it and looked and it wasn't there. It's just 3 blobs of solder but no chip. I had to rob another cap for a rca 32" power supply to get it going since i'm stumped on this one. When i get some more caps in i'll pop it in and proceed with some of the other regulators and try troubleshooting some more. Maybe the 5.1 volts is correct on U4
        • questor42
          • May 2011
          • 14
          From what I have seen the VW42L HDTV10A and VX42L HDTV10A
          mother boards do not have a U4 and it's not in the parts list either.
          • rmoody
            Learning Member
            • Jul 2011
            • 262
            Hey Bill, Do you think the Tcon board could have anything to do with my problem?
            • PlainBill
              • Feb 2009
              • 7034
              Possible, but unlikely. I'd try disconnecting the tcon and seeing if you can now get sound. IF that happens, by all means replace the tcon. If the TV shuts down, or if you still have the same symptoms, that is probably not the cause.
              PlainBill
              • rmoody
                Learning Member
                • Jul 2011
                • 262
                #27
                PlainBill
                Good advice I'll try that. I got another cap to go back in my main but haven't had time to get it in. I'll do that and try pulling the tcon cable. Thanks Bill
                • rmoody
                  Learning Member
                  • Jul 2011
                  • 262
                  #28
                  OK Bill, I tried unplugging the tcon and it just backlit the lcd with no colors but that's typical i think with a bad tcon. I also checked fuse on tcon and it was good. From the manual I have checked everything and all seems good except for that weird U4. The Manual says it should have 3.3 volts out but it has none but it has the 5 volts in. I don't understand how the manual can show an out voltage without a regulator even being there. After that the U33 voltage out was supposed to be 3.3 volts and it's only reading about 2.3. All other components tested well.
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    #29
                    When in doubt, change it out. I wouldn't suspect a part for a week and not have it on the way in the mail. These parts are cheap. If you can spare a dollar or two, take a risk. You've come this far.
                    • rmoody
                      Learning Member
                      • Jul 2011
                      • 262
                      #30
                      Board or component?
                      Boards are very hard to find for this model.
                      • saturnknts
                        • 8
                        #31
                        Board or component?
                        component. i'm working on one and its about 20 bucks shipped from mouser unless you need chipquik like i did which makes it almost 30 bucks shipped.
                        you might also consider ordering caps for both inverters as 3 of four of mine were bulging. i can give you part numbers if you like. and ill let you know if all my parts work later tonight if the usps hurries up
                        • rmoody
                          Learning Member
                          • Jul 2011
                          • 262
                          #32
                          I'm at a loss of what components to try on the main board. No bulging caps at all. I really don't think it's the inverter since the keyboard controls don't work. Only way to power down is to unplug.
                          • saturnknts
                            • 8
                            #33
                            okay, rmoody. First off ignore U4 and ce9 and ce10. all three DO NOT have anything on or in them. leave them alone.
                            as stated yesterday i used the following parts and probably over killed the replacement of caps, but since i dont have an ESR meter yet i felt better safe than sorry. and yes i always order one extra of everything in case i screw up. although since there are 17 of the 220uf caps it was cheaper to order 25
                            here is what i ordered from mouser and im sitting here watching this TV right now, previously it was a gray backlit screen and only able to turn off via unplugging it...
                            Mouser #: 910-SMD1
                            Mfr. #: SMD1
                            Desc.: Soldering Tools SMD Removal Kit
                            QTY 1 $13.50
                            removes u8, u2, u33, u7, u9 nicely
                            Mouser #: 621-AP1117E18G-13
                            Mfr. #: AP1117E18G-13
                            Desc.: Low Dropout (LDO) Regulators LDO BI 1.0A
                            1.3V 12V 5.0V 1.8V FIX
                            QTY 2 $0.44
                            used for u9
                            Mouser #: 511-LD1117ASTR
                            Mfr. #: LD1117ASTR
                            Desc.: Low Dropout (LDO) Regulators LOW DROP
                            FIXED REG
                            QTY 5 $0.91
                            used on u8, u2, u33, u7
                            Mouser #: 667-EEU-FM1E221
                            Mfr. #: EEU-FM1E221
                            Desc.: Aluminum Electrolytic Capacitors - Leaded
                            220UF 25V ELECT FM RADIAL
                            QTY 25 $0.218
                            used on ce75, ce8, ce7, ce14, ce16, ce91, ce2, ce1, ce5, ce6, ce23, ce11, ce27, ce18, ce25, ce26, ce20
                            Mouser #: 667-EEU-FR1V471
                            Mfr. #: EEU-FR1V471
                            35VDC 470uF 10x16mm LS5mm
                            QTY 5 $0.71
                            used on the two inverter boards, again 3 out of four of these caps were bulging so even if yours are not currently i would suggest just replacing them to save later hassle
                            attached BOM for mouser as well.
                            regards,
                            TIM
                            • rmoody
                              Learning Member
                              • Jul 2011
                              • 262
                              #34
                              sweet, I have 20 of the 220 uf caps so i might try replacing the rest of them, I've replaced 5 or 6 of them already and tested the caps with a capacitance meter and they all read good but i still replaced them. Haven't even looked into the inverter yet so i might try that too.
                              • rmoody
                                Learning Member
                                • Jul 2011
                                • 262
                                #35
                                Well i found another board that was very very close on numbers and it looked exactly the same so i bought it. Got it put in and got the same screen except this time i could see the menu but i was still getting the vertical lines as seen in the picture above. I pulled the inverters and checked all 4 caps and they were all well within limits. They read about 476uf. Checked fuses on both inverters also. I've just about tried everything except a new panel. I'm afraid that's what it's coming down to. Also with the new board the keyboard controls were working just couldn't make out anything on the screen. SMH
                                • questor42
                                  • May 2011
                                  • 14
                                  #36
                                  On a capacitance meter they can measure close to their correct values But still be bad.
                                  It happened to me, a brand new cap was bad. I borrowed a ESR meter and tested all of the caps on the power section of the board that tested good with a cap meter and found 6 that were bad.
                                  So the can look good and test good and still be bad.
                                  Read article at http://ludens.cl/Electron/esr/esr.html
                                  for more info and how to build your own ESR meter
                                  • rmoody
                                    Learning Member
                                    • Jul 2011
                                    • 262
                                    #37
                                    Well now that you say that i can believe it because i just pulled 5 extremely bulged caps out of an amp and every one of them read within range. Any suggestions on an esr? I had thought about a cap wizard.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Overpriced, I would have to say. If you have a good capacitance meter, the Bob Parker Blue ESR meter would be appropriate. If you need both Capacitance and ESR measurements, the ESR-Micro V4.0 is a good deal.
                                      PlainBill
                                      • questor42
                                        • May 2011
                                        • 14
                                        #39
                                        I agree with PlainBill they are over priced, The ESR meter that I borrowed was a cap wizard it worked well but I had to do some repairs to it before using it, The battery came out and the buzzer was loose inside shorting out on the circuit board.
                                        There is nothing high tech inside of it to justify the cost. I am building my own with all the same features as the cap wizard.
                                        There are a lot of choices but the Blue ESR meter is a good choice and you can save some money by getting it in kit form
                                        • rmoody
                                          Learning Member
                                          • Jul 2011
                                          • 262
                                          #40
                                          ok so i'm still stumped with this one. I replaced U33 and now the keyboard controls work but I still have the same vertical lines. Does anyone else have any suggestions. I also tried a replacement board from tristatemodule but it didn't change anything. I didn't check any values on that board just tried it and pulled it and sent it back. Is it possible that it could be a panel problem? Really about to pull my hair out on this one.
                                          • ggil44
                                            Vizio M65-E0 No Picture, No Sound
                                            by ggil44
                                            Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                            09-03-2024, 08:30 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
