Polaroid TDA-03211c IPOS150 Power Supply Problem
Re: Polaroid TDA-03211c IPOS150 Power Supply Problem
http://m.imgur.com/iZGFSoW
http://m.imgur.com/v0q1F9UComment
That is definitely bad. Use Panasonic EB series to replace. I had 2 22uf 450v bad on mine.Comment
Remove the black plastic disc on top of the cap to see if the cap is actually domed because sometime the plastic disc is deformed.
The two 22uF 450VDC are in the inevrter section which commonly failed.
Also post the whole board picture of YOUR board so we see how it is.Last edited by budm; 03-05-2015, 06:33 PM.Never stop learning
Where is the inverter located? Here's the pictures
http://imgur.com/4L9cMlA
http://imgur.com/lZRUKcrComment
Also whenever I put a flash light against the TV I can see the blue screen, whenever I press the menu button I can see the menu pop up.. I tried to play a music cd in the dvd player and the sound works.Comment
You have power supply/inverter board combo.
The two lytics caps just above 'PROVIEW' are the commonly fail caps for the inverter circuits, the two transformers to the left of the caps are high voltage inverter transformer.
You have make sure first that the PFC Voltage booster cicuit is working by checking the DCV right at the two legs of the cap, when TV is switched on, the DCV should be >360VDC, the inverter circuit needs that to operate + other command signals.
Bad cap can look normal.Never stop learning
http://imgur.com/xCrtHbpComment
C13 was never installed, but that is in the PFC Voltage booster section.
So as I stated in post 28, do you have Boosted DCV on the main filter cap?Never stop learning
http://imgur.com/6fzOaTkComment
The red stuff is the adhesive used for keeping the part in place during the soldering phase.Never stop learning
https://www.facebook.com/Telford-Tel...7894576335359/Comment
OK, I replaced the 2 22uf 450v that you guys mention, and now the tv is working,.. I guess you were right about bad caps looking normal..
I also have a Vizio E470VL tv that doesn't come on, only the orange light comes on.. But this is the wrong thread to ask for help,But if anyone have any links please post them..Comment
OK, thanks for the repair follow-up.Never stop learning
I also have a Vizio E470VL tv that doesn't come on, only the orange light comes on.. But this is the wrong thread to ask for help,But if anyone have any links please post them..Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
