Samsung LN32B360C5DXZA Sound OK, No Video
  • Wizard
    • Mar 2008
    • 2296
    Re: Samsung LN32B360C5DXZA Sound OK, No Video
    Don't think about it. Test turn on by jumpering with a resistor from standby supply to (power-on) to see if power supply responds at the connector. The powering on sequence is complex due to PFC circuit.
    Cheers, Wizard
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Originally posted by Dgtech
      Here is more of what I am noticing with mine:
      All voltages seem OK whenever the board is powered up without the processor board being plugged in. It's as if the processor board is somehow telling the power board to shut down. The 5VDC on the connector is solid, but whenever the other board is plugged into this one via the ribbon cable, it goes from 5VDC to 0 four to five times and then quits.
      So ok... When I did this test before, I didnt have the board plugged into the CCFL lamps. Just now, I had the board itself powered up with the CCFL's and just without the ribbon to the control board and guess what, the backlights were on full brilliance (10 mins no problem). I then plugged in the connector and got the usual, power up samsung music/sound - 5 blinks of the power LED - and no backlights at any time.
      I'm now thinking that the power board is fine now but somehow the control board is telling it to turn off. Is this sound thinking?
      • fastvideo
        • Dec 2008
        • 55
        #1 Sound is working. As you have already said at the first post.
        #2 Please if you can confirm image is presents with a flash light.
        I still think it is only back light problem.
        Check back what I have pointed out on post #10, 11 and 14.
        If there is no ON signal drive at PC802S, UB802 somehow is turning INV_UVLO to an On state.
        Should check if UB802 and related component is having problem.
        That is why I ask if I can try forcing the UI801 to On state at post #20 which Wizard doesn't like the idea.
        • alexanna
          • Mar 2010
          • 1346
          I am sure there some major differences in Tvs and LCD monitors, But on a LCD when I get back lights to come on only when the ribbon to the LCD panel is disconnected a lot of times it can be traced to a marginal LDO regulator, Have you checked these?
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Thanks for the advice both of you.
            I have tried to check that voltage out but I can't locate a spot on the front side of the board for that PC802S or UB802.
            I think I may have confused the conversation when I thought it was the same problem. I think this is different. I posted the pictures below to show how the backlights work without the control board connected. They will stay on as long as I leave it this way. Have you tried it this way - fastvideo? If the backlights are off on yours under this scenerio, then we definitely have different problems.
            When the connector is plugged into it, connecting the control board, the backlights drop out and yes you can see the image with a flashlight.
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              #26
              I also add that I was watching tennis for a while on this set earlier. I noticed that whenever I do have the control board powered up and running, the processor (with the heatsink) gets kinda hot. I can barely keep my finger on it.
              • turfman
                • Apr 2012
                Needed to dig this thread out of the cellar. I have one of these units that the screen just continually blinks on and off. If I unplug the main board it will stay on solid, but no LED's either way.
                • BeTronics
                  • May 2013
                  Thanks for your posts on this unit. The schematics and notes helped get a start to troubleshooting one of these that a friend had. The symptoms were different... no power up and no sound, no musical beeps on power up. Repaired by replacing ZM801 (1N4740A, Zener diode) and QM801 (STU418S, MOSFET) Not sure if it would help in other fault scenarios for this model. Looking at the board, I believe a second diode / mosfet driver is used in the same section, which may could possibly control another portion of the control feedback, allowing the sound to be enabled but still no video... just a thought... not proven ... Brad
                  • rlega
                    • Jan 2014
                    • 93
                    I purchased a Samsung LN32B360C5DXZA for $25 and like the title shows, the TV had sound, but no picture.
                    I searched online for the issue and I found Badcaps. I read all the posts and I saw a picture that someone posted where it shows the 3 diodes. I checked the diodes on my power supply board and got the following readings:
                    DP810 - 485k (reverse test showed infinite like it should)
                    DP804 - 506k (reverse test showed infinite like it should)
                    DP805 - Open diode in-circuit as well as out of the circuit
                    I did a search online and I was not able to find the same diode (DP805 - MUR360AX SSG 09083).
                    When it comes to capacitors I can find them online, but I'm having trouble finding the diode. Can anyone give me a hand?
                    I'm attaching a clear picture of the power supply board and marked the diodes reading.
                    • rlega
                      • Jan 2014
                      • 93
                      Is anyone able to help me with the diode that its bad on the TV so I can purchase it and replace it?
                      I found these two online but I do not know if it will work:
                      1N5408 Rectifier Diode 3A 1000V
                      1N5400 B, Rectifier Standard Recovery NS, FBGA48
                      • rlega
                        • Jan 2014
                        • 93
                        I found replacement diodes for the TV, because I could not find the MUR360AX. I ordered them, and walla, the TV is working.
                        I found them on eBay (Seller: maziz3)
                        • Lenny63
                          • Jun 2016
                          • U S
                          #32
                          Hello new to this form . my name is Lenny
                          • gl4709
                            Samsung un55cu7000d with backlight and sound No Video / Picture
                            by gl4709
                            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                            01-23-2025, 06:21 PM
                          • Max514
                            Samsung UN55H8000 sound but no backlight no video
                            by Max514
                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                            • Unplugging the main board cable at the power supply >>> backlights came on.
                            • BLU_ON signal from the
                            04-14-2022, 10:34 AM
                            09-07-2024, 05:50 AM
                          • alro7779
                            Samsung UN55MU6103F video problem; has colored stripes on the display
                            by alro7779
                            Hello, everyone!
                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                            09-27-2025, 11:29 PM
                          • soeren
                            A2442 - No sound over internal speakers and no video playback
                            by soeren
                            I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                            All happened after the battery ran out of power overall several days when I was on vacation.
                            I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                            07-26-2024, 01:24 AM
