i apologize for not posting pictures
  • freefixkorma
    • May 2011
    • 11
    Hi guys i have a LG-50pg60 au the thing is went off suddenly and than never came back ,i check one of the fuses ,was burn out ,and i replace it and the ,i put back everything and plugged the power on ,and again the fuse burn out again ,i am sending some pictures i am sorry i did not post pictures before ,how can i test what is burning the fuse ,i will appreciate any guide to figure what can i replace any part hopefully you guys can determine with pictures what steps to take any additional info please contact me i will appreciate any help to determine if power supply board is good or not thanks in advance
    freefix
  • retiredcaps
    • Apr 2010
    • 9271
    Re: i apologize for not posting pictures
    AND multiple postings are also frowned up. Keep everything on one thread otherwise people get confused and will give up helping.
    --- begin sig file ---
    --- end sig file ---
    • freefixkorma
      • May 2011
      • 11
      please moderator can you delete this thread please sorry about that i apologize
      freefix
      • howardc64
        Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
        by howardc64
        Eventually discovered a burn mark near lower corner of LCD. Here is a summary
        • Backlight on, no image
        • Disconnect right buffer board (view from front), left side display comes on
        • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
        • Buffer board is pretty simple
        Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
        07-11-2025, 04:04 PM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • bohaboha
        Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
        by bohaboha
        Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
        anyhow i couldn't t read anything else
        the backlight is on strong and the screen does not get dark or very dark but no pictures
        the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
        01-02-2025, 08:04 PM
      • valvashon
        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
        by valvashon
        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
        11-24-2024, 12:08 PM
      • ktmmotocross
        Dell G15 5511 LA-K455P - new gpu fan burn SIO pwm sig. in SIO MEC1515
        by ktmmotocross
        Hello. Have this Dell G15 5511 la-k455p that new gpu fan burn and left pwm sig from sio with 10 ohms.
        I read that this sio MEC1515 must be programmed, but someone says dont. My Vertyanov seems dont have this model in it.
        Laptop works and can be tricked by split pwm, but i dont want to do this stuff this way.
        So anyone really knows if it must be programmed?
        09-16-2025, 07:11 AM
