polaroid flm- 1514b power prob and fix!
  • cadillacman
    • Feb 2011
    • 524
    figured i would post this. Picked this up tonight for $10. Was sad to see screws missing but what the hell..
    the former owner said it would power on and off intermittently, most of the time it would just continously cycle power and you would have to unplug, replug several times before it would power up and work. Once on it would stay working..
    I confirmed the issue, plugged it in and the power would just cycle every couple seconds..
    Pulled her apart, caps are no name but all visually look o.k.
    On a hunch i replaced the small 22uf startup cap. Also reflowed some questionable but NOT obiously bad solder joints. Put the ps back in and she fired right up!! YAY one cap fixed this yes one.
    If i was keeping this i would probhably recap the entire supply and mainboard but for what im doing, shes done and ready to rock!
    Ive powered it on and off several times as well as unplugged, she fires up every time.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: polaroid flm- 1514b power prob and fix!
    Classic sign of a capacitor with high ESR. As the cap warms up, the ESR drops enough for the SMPS to start.
    --- begin sig file ---
    --- end sig file ---
    • cadillacman
      • Feb 2011
      • 524
      yeah, if only they were all like this.. i go from this to headscratchers like that phillips and that jvc im working on..
      so do you think if i would have heated that little cap with my iron the tv mightve powered on? if so mabye thats a technique i will employ in the future. ( woul dhave to put the iron on an iso though correct?)
      • retiredcaps
        • Apr 2010
        • 9271
        Some people use a hair dryer to heat up caps.
        If you are going to do a lot of TV repairs, it might be worth $50 to $75 to get an ESR meter.
        Maxxarcade, who is a member here, also has youtube channel and he has a number of videos posted (some very recently - 7 in the last 10 days) showing how he repairs TVs, LCDs, etc. He has one video showing his ESR meter and how he uses it to verify caps.
        And yes, he is in the acrade repair business.
        http://www.youtube.com/user/Maxxarcade
        • cadillacman
          • Feb 2011
          • 524
          wow thats cool!!!! thanks for the links man..
          fyi been been running this tv all day today and still going strong
          a sa fellow arcade nut i guess ill have to have a chat with maxxarcade someday.
          • Aircat
            • Nov 2011
            My 1514B had a similar problem where it would start blinking after a few minutes and eventually turn off. I assumed it was the capacitor in the power supply shown here in this thread. It turned out not to be. I replaced that cap and it still had the problem. I finally traced it down to the 1000uf cap (the largest one on the main board). I figured while I had it apart I'd replace all of them. Works fine now.
            • alberthabib
              • Oct 2012
              please what types of polaroid flm-1514b replacement capaciters
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • hill01
                Samsung UE75MU7009TXZG Endless Power Cycle
                by hill01
                Hi everyone and thanks in advance for any help I might get here
                My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                Since a few days, the TV won't turn...
                11-17-2021, 02:52 PM
