Panasonic plasma TH-42PZ80U 2 blink 15v SOS
  • jettboat
    • Nov 2012
    • 63
    Re: Panasonic plasma TH-42PZ80U 2 blink 15v SOS
    Where should I be finding 15v tp ? Vscan did seem low to me. when the screen powers up the power supply gets loud like inverter under stress so I don't leave it on more than a few seconds last time the 16n55g blew this is my 3rd set
    • jettboat
      • Nov 2012
      • 63
      Also I personally didn't replace the TEA1611T plus caps on MC201 and MC301, it was done by a student 3 quarters behind me that could not fix it, this is how I acquired the set
      free
        SM:
        Pins 15Vc in schematic for P board.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #44
          are mc201 mc301 the same moduels could the previous repairer put them in wrong would this cause your fault? just thinking aloud here i dont know what these moduels are for.
          • jettboat
            • Nov 2012
            • 63
            thanks didn't have SM for schematic this one should be much easier than the "panny tnpa4782 issues" will test shortly
              They have slightly different part #s so I presume it's possible to put them the wrong way around and have it not work.
              The modules generate the drive waveforms for the 16N55G's.
              • jettboat
                • Nov 2012
                • 63
                Unknown didn't even think they would have put them in wrong the boards were removed to do the repairs. Just looked there the same parts but possibly the ic are installed wrong? I have done 3 or 4 of these Panny's with 10 & 2 blinks really easy usually.
                • jettboat
                  • Nov 2012
                  • 63
                  I have the 15.9 @ connector p6 seems little high
                    Mine gave 15.7V (no blinks); that sounds fine to me.
                    • forefrazier
                      • Aug 2014
                      • 7
                      Brand new here with the same problem on my TH-C50FD18. Did not want to risk soldering parts so bought a new PS board from Panasonic Factory Outlet Store online. Swapped out the entire board and I still have the same 2 blink issue. Another bad board or something else causing the problem? I also do not know which location is MC201 vs. MC301? When testing the boards with refrigerant to cool, the one on the left seems to be the problem. Any help is appreciated as I just paid a pretty penny for a "new" board and didn't fix a thing. Thank you!
                        So on your NEW board, does freezing it make any difference?
                        • forefrazier
                          • Aug 2014
                          • 7
                          Yes...I froze the same board and TV came on and worked for about 30-40 min until it shut down again.
                          • forefrazier
                            • Aug 2014
                            • 7
                            Sorry..meant to say I froze the same IC chip/capacitor at the same location and the TV worked with the NEW board for approx. 30-40 min.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #54
                              sounds like you new board is faulty too do they offer a return policy?
                              • forefrazier
                                • Aug 2014
                                • 7
                                Yes. I believe so.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #56
                                  Originally posted by forefrazier
                                  Yes. I believe so.
                                  wait and see what toms and tw2005 thoughts are too if you want but im my opinion your new board is bad too. I take it you dont want to try to replace the old capacitors on your old psu yourself? How good are you at soldering the points are a little small but the job is doable with patience i have done this repair my self and my sets still working great.
                                    Or, in the worst case, there are sellers on eBay doing this repair service for less than $100.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Was it this place?
                                      http://panasonic.factoryoutletstore....er-Supply.html
                                      If so i very much doubt Panasonic has anything to do with it, by their own website they're "independent retailer of consumer products"
                                      I'd put a ? on whether it is in fact Brand New.
                                      • forefrazier
                                        • Aug 2014
                                        • 7
                                        Originally posted by tw2005
                                        Was it this place?
                                        Yes. That is the place. I understood when I bought the board that it was not actually coming from Panasonic but this was the only place that said the board was new. Now that I have done more research, I probably should have either sent my board to someone to fix or tried to do the repair myself.
                                          If you paid by CC/PayPal then I'd first try negotiating with seller to send board back. Clearly faulty board. If that fails then file chargeback or complaint with PayPal.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
