Polaroid TLA-04011c Red Light on, no power on
  • ryn0909
    Professor X
    • 122
    Re: Polaroid TLA-04011c Red Light on, no power on
    well i returned the board i bought off of ebay, and purchased another one for $85 from a different seller on ebay. tv will power on, blue light on, backlights come on but screen is blank, no blue screen or logo
    • SlickClick
      • May 2011
      • 91
      #62
      Im not trying to do a thread High Jack Here... But I have a similar problem where the Red Light comes on and when the power button is hit the Blue light comes on and the screen illuminates -ie backlights come on- and nothing more... The Guy who gave me the TV put it in the Shop and they told him it needed a Power Supply...
      So I searched around the internet and I found a Video of a guy who repaired all the caps on his Power Board and it fixed this same problem...
      My problem is I removed the Caps from the Board, only noting where 3 of them went... So I have 7 Caps I dont know where which on goes...
      4 - Black 16v 1000uF
      3 - Brown 35v 470uF
      I got the factory Service manual in PDF but the image is crap...
      Can anyone or does anyone have a pic of the row of Caps along the left side of the power board under the Aluminum Heat Sink Transistor Panel or the Values of:
      C50 thru C53, C55, C56, C61, C64, C65, & C66
      I believe C56 & C61 are 25v 470uF & C53 is 35v 470uF
      • ryn0909
        Professor X
        • 122
        here ya go bro....
        c50 thru c53-- 35v 470uF
        c55,c64,c65,c66-- 16v 1000uF
        c56,c61-- 25v 470uF
        • SlickClick
          • May 2011
          • 91
          #64
          Thanks Ryn... I installed all the New Caps; But It didnt fix my problem... I have the same model as Listed here on this thread... the TLA-04011c...
          The Website, the guy has the same issue on that you asked for is:
          http://www.polaroid-tv.com/polaroid-lcd-tv/parts/
          Its a different Model Polaroid but same issue...
          Now Back to Figuring out what is really going on here... Cause this TV is Nice and I got it for free so Id like to fix it... So Far I only got 20$ into it... But Id be nice to figure out why it Turns on But No Picture...
          Service Manual says to "Change AD Board Box" But what the Hell Part is that..?
          This Polaroid Service Manual should be packaged in the Toilet Paper Isle... Cause I swear its by far the Worst Book ive ever tried to read, and the schematics are garbage cant even read them...
          • ryn0909
            Professor X
            • 122
            well this is where im at....... at FIRST, i had red light on but no power or blue light... i replaced the main board with a used one, i then got it to power on and show a blue screen, but no logo or anything else. After figuring the board to be bad, i sent it back and ordered a different one from a different seller. I installed the 2nd used board and now i got it to power on with blue light on, the backlights are on, but the screen is black...... and thats where i sit with it...... lol
            • SlickClick
              • May 2011
              • 91
              #66
              OK so per the "service manual" and at the advice of the previous posters of this thread to check the transistors on the "Main Board" I did the Following with the Following Results...
              Per Service Manual:
              -Note All Tests were done with Unit complete connections as photoed in Pic1-
              Check Pin 7 of the "D-Sub 37 Pin" Connector;
              Is pin 7 Active High..? = Result: 1.287v
              Check Inverter Power (24v) of LCD Panel OK?
              All Reds = 23.6x volts at power supply and inverter board
              Check Pin 5 of DS37P Conn. Active Low (see panel Spec)?
              Pin 5 = 3.239v
              That completes the Service Manual Checks all results end in what they call changing the "AD Box" which I assume is the Main Board... =/
              -Note: it seems to me that the "high" of pin 7 is Low and the "low" of pin 5 is High.-
              Additional Tests Done by Me... I tested most all the Transistors on the Board... For the Most part they all seem to within Spec Except for the Following on the Main Board...
              -Note all Voltages are placed on the Pins as how the appear on the Main Board Installed-
              A1
              U4 & U8 = AS117L
              B064024
              .034v
              U4 = 1.283v 1.289v
              3.237v
              3.238v
              U8 = 1.480v 1.480v
              .228v
              UTC
              U35 = 78T05AL
              eb UAOC
              11.97v
              U35 = NC -.020v
              4.93v
              These Numbers Look some what out of sync with what I think would be Normal -granted im not a TV repair guy but i've had training in micro electronics- My concerns are the very low #'s on U4 - .034v and U8 - .228v Now U35 Has a Neg (-) voltage meaning it could be ground, but all other transistors like these have had a positive (+) voltage reading on those sides.
              The
              -CN3- Blue Remote Wire from Power Board to the Main Board -JP1- read 4.44v
              -CN3-Orange V2 wire from the PB to MB -JP1- read 11.97v
              -CN3- Red V1 & VSB Wires on PB from MB -JP1 read 4.85v
              -CN4- Brown Wire from MB -JP1- Read 23.61v
              All Black Ground Wires on PB & MB Equal a Negative (-) .0xx Voltage
              All Red Wires from PB's CN2 & CN4 to the LCD Panel Inverter Read 23.6x Volts
              Any Advice or Help with the situation would be great...
              Forgive me for not Highlight exactly where on the circuit board the "U" transistors are I cant find my photoshop CD to install on this Computer...
              • PlainBill
                • Feb 2009
                • 7034
                Per Service Manual:
                Pin 5 = 3.239v
                A1
                U4 & U8 = AS117L
                B064024
                .034v
                U4 = 1.283v 1.289v
                3.237v
                3.238v
                U8 = 1.480v 1.480v
                .228v
                UTC
                U35 = 78T05AL
                eb UAOC
                11.97v
                U35 = NC -.020v
                4.93v
                The
                You certainly put in a great deal of work, but there are a few problems. Let's deal with them one at a time.
                While Photoshop is an excellent piece of software, using it for labeling pictures is similar to using an elephant gun to kill a fly. Microsoft included a flyswatter grade program in Windows. It's called 'Paint'. OK, Paint is more rolled up newspaper grade, but it does the job.
                The readings on U4 and U8 don't make a lot of sense. Let's start over on those. I've attached a picture for the standard package of the AS1117 regulators. Pin 1 is either Gnd or the Adj input. Pin 2 is output, pin 3 is input. The tab is electrically connected to pin 2.
                The AS1117 family comes in fixed and adjustable versions. The usual part number for the AS1117 family is AS1117L-n.n where nn is 1.5, 1.8, 3.3, etc.
                PlainBill
                • SlickClick
                  • May 2011
                  • 91
                  #68
                  As per your Posted Thumbnail and Info...
                  U4: Pin1= .034v Pin2= 1.283v Pin3= 3.237v and Tab= 1.289v
                  U8: Pin1= .228v Pin2= 1.480v Pin3= 3.238v and Tab= 1.480v
                  There is no -n.n value on these components... Only the #'s I listed previously...
                  My previous posts spacing on the values were shifted by the forum system; so they did appear as I intended...
                  I included the pic of the Main Board again with so Paint on it... LoL
                  Thanks for the Insight and Help...
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #69
                    1) For U4 and U8, what are you using for ground? That is, where are you putting your black probe?
                    2) All your voltage readings in post #66 seem to be on the low side?
                    a) What is the make and model of your multimeter?
                    b) Change the batteries in your multimeter and re-measure U4 and U8 to see if there is a difference. Some multimeter will give incorrect readings even though the low battery indicator is not lit.
                    3) The reason for all the above is that most voltage regulators have a 1% tolerance. So a 3.3V DC regulator can be
                    3.3 x 1.01 = 3.333
                    3.3 x 0.99 = 3.267
                    So if you are reporting 3.238, this falls outside the 1%. Since you are reporting 4 digits, I'm assuming you have a decent 4000 count multimeter? Most of the cheap ebay 830 variations are only 3 1/2 digits or 2000 count.
                    --- begin sig file ---
                    --- end sig file ---
                    • SlickClick
                      • May 2011
                      • 91
                      #70
                      I have a Protek 506 Digital Multimeter... The Below Spec sheet says its a 3 3/4 Digit...
                      http://www.protektest.com/ProdInfo.asp?prodId=506
                      I will try with a fresh battery and see if it makes a difference...
                      I am Using the Chassis as Ground/where I clip my multimeter...
                      Update:
                      Put a New Battery in my Protek506 -it had a new one in it too that i put in a couple weeks ago none the less I tried it with a Brand New one- Same #'s on U4 & U8
                      I have another Digital Meter a Craftsman 82014 and put the New Battery in it and tested; results were slightly lower on this meter by no more than x.x16 the least varied by x.xx2
                      Results as follows:
                      U4: Pin1= .031v Pin2= 1.273v Pin3= 3.215v and Tab= 1.273v -Craftsman-
                      U4: Pin1= .034v Pin2= 1.283v Pin3= 3.237v and Tab= 1.289v -Protek-
                      U8: Pin1= .226v Pin2= 1.470v Pin3= 3.215v and Tab= 1.470v -Craftsman-
                      U8: Pin1= .228v Pin2= 1.480v Pin3= 3.238v and Tab= 1.480v -Protek-
                      • ryn0909
                        Professor X
                        • 122
                        so as far as your tv goes, where you at with it? power on, backlights on but no display?
                        • SlickClick
                          • May 2011
                          • 91
                          #72
                          Yes Ryn... Light toggles on to Blue Back Lights Come on but But No Image or Sound... There has to be an Issue with the Main Board... I wish I knew what Polaroid did to repair/refurbish these boards... If someone out there had a good working board to give us good #'s off of...
                          or if I could get a CLEAR READABLE Schematic; that would be nice too..!
                          • ryn0909
                            Professor X
                            • 122
                            the person i bought the second board from is some kinda electronics tech i guess, and he sent me some instructions on checks to perform on the board he sent me, ill pull it from my email and post it here in a few
                            OK so i attached a txt file with all the checks he had me do..... hope this helps ya out
                            • SlickClick
                              • May 2011
                              • 91
                              #74
                              Are these tests supposed to be done on the Green "Main Board" or on the Power Supply Board..?
                              • ryn0909
                                Professor X
                                • 122
                                the main board
                                • SlickClick
                                  • May 2011
                                  • 91
                                  #76
                                  Ok took me awhile to Locate all the test points but here are my results:
                                  J7 = 10.97 - 11v
                                  J8 = 10.96 - 11v
                                  TP17 = 3.242v
                                  TP29 = .57Xv
                                  TP30 = .026v
                                  TP33 = .037v - .031v
                                  U35 = Pin1= 11.97v Pin3= 4.93v
                                  According to the Tests Procedure Provided;
                                  J7 & J8 - are supposed to be between 12v-18v; Which they are not...
                                  TP17, TP29, & TP30 - are supposed to be at 5v; they are not...
                                  TP33 - Is to be a "Digital Signal" which this appears to be; if it is at the right level I do not know because I dont have an oscilloscope...
                                  U35 - Appears to be within acceptable Voltage Range...
                                  I have Included Pics of where and what was tested...
                                  What and where to Check Next..? Do I go Back to the Power Supply or is the Issue within the Main Board..?
                                  • ryn0909
                                    Professor X
                                    • 122
                                    thats my question.... the guy hasnt responded to my email yet
                                    heres what i got when i did my checks....
                                    J7-11.03vdc
                                    J8-11.03vdc
                                    TP17-3.28vdc
                                    TP29-0.19vdc
                                    TP30-0.00vdc
                                    U35- Leg1-12.13vdc
                                    Leg3-4.99vdc
                                    So it appears that you and i are have the "exact same" issue going on........ lol
                                    • ryn0909
                                      Professor X
                                      • 122
                                      hey slick, question for ya....... on the back side of your mainboard, does it have a jumper-like piece soldered to the board, similar to the one in the pic i attached?????
                                      • SlickClick
                                        • May 2011
                                        • 91
                                        #79
                                        No Ryn; that is an Obvious repair... Have you tested across the Jumper for power..?
                                        • ryn0909
                                          Professor X
                                          • 122
                                          no i have not yet...... however i was told that jumper it part of a revision upgrade for the replacement mainboards that was done BY Polaroid themselves...... ill let you read the emails, i attached them in txt file.
                                          ALSO...... here is the other email i was loooking for, that was sent by the seller of my recently purchased board....
                                          1) Flourescents/backlights have a feedback to the main board/SSB and communicate with the FPGA.
                                          So-if any of the flourescents are leaky or not putting out sufficient light, the OCP (Over Current Protection of UCP (Under Current Protection) will tell the microprocessor to activate PD (Power Down).
                                          2) The T-Con (Timing Controller) also gives feedback to the microcontroller (which is on the board that you purchased) to
                                          shut the screen off.
                                          It is very difficult to troubleshoot without a DSO (Digital Storage Oscilloscope) because of the nature of the digital signal.
                                          We always try our very best to make sure the customer's problem gets resolved because that is how we have built our business in the past 40 years. We feel bad you are having an additional problem which does happen.
                                          Hope this helps.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            Laptop computer that went completely dead no boot no power light no hard drive light
                                            by sam_sam_sam
                                            See pictures for type of laptop computer
                                            I checked switching power supply brick 19.2 volts multi meter only
                                            No booting without switching power supply connected
                                            Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                            What the heck is going on here...
                                            04-04-2025, 04:58 AM
