Philips 42PFL9632D/10 inverter failure
  • PowerAmpFreak
    • 982
    • Sweden
    Hello. Set came in with sound but no picture. Found a blown control-IC (BD9897FS) on the slave inverter board. The slave and master inverter boards are sold as a pair very reasonable priced, but the question is does the blown ic indicate a failure elsewhere and risk to blow the new boards?
    Or can I summarize this as ordinary part failure?
    Thanks!
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Philips 42PFL9632D/10 inverter failure
    Without pictures, I'm assuming that these inverters are the ones that have been made for several sets and is a common failure as seen here in my post (#29):
    https://www.badcaps.net/forum/showth...974#post129974
    After seeing about two sets with this same failure, I quickly purchased about 10 of those chips on ebay (BD9897FS). You can replace the chip for about $10 or replace one board for $50 plus shipping. Some replace both boards as a pair but I dont buy it. Keep the repair as cheap as possible.
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      I also wanted to add that there is a known defect either in the chip or in the circuit design.
      I replaced a chip on the slave board on one set with the same exact symptoms - sound but no picture. Then about six months later, the same set had no sound and no picutre. This time the master board had that chip blown instead of the slave. Again the chip was replaced and it's been working for about a year now. Bad batch of chips?? Who knows. I have a feeling that keeping the brightness & contrast lower on these sets will reduce the rate of failure of these chips.
      • PlainBill
        • Feb 2009
        • 7034
        Somewhere around here is a link to a circuit modification LG has ordered for these inverters. I would think that performing that mod would be a very good idea.
        PlainBill
        • PowerAmpFreak
          • 982
          • Sweden
          Buying the chip alone from my dealer is 30$, buying a pair of new inverter boards is 72$ so I will chose the pair of new boards. Hopefully the mod is done to these new boards.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Wow. Dealer my ass. Theres no deal there. I found one on Ebay for 4.25 plus 2.50 shipping = grand total of 6.75. If that's not worth it, I dont know what is. $6.75 vs $72 for new pair of boards is about ten times the cost. The mod usually will not be done on the boards. They are usually direct replacements.
            Here is the post where it has the modification plans for the inverter board. #48
            https://www.badcaps.net/forum/showth...t=10215&page=3
            • npielawski
              MacBook Pro late 2016 (820-00239) with multiple failure modes.
              by npielawski
              I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
              I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
              10-15-2025, 01:53 AM
              12/24 volt compressor cooler box inverter capacitor failure
              This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
              Found a 47uf@63 volts double the ESR value of a new one
              The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
              The main filtering capacitor was not replaced because I did not have that was not too tall
              Where the 220uf capacitor is some type of switching power...
              08-30-2022, 05:28 PM
            • alro7779
              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
              by alro7779
              Hello, guys!
              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
              09-14-2025, 12:25 AM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • Gentian
              APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
              by Gentian
              I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
              It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
              03-06-2023, 07:07 AM
