Tv turning on and off, capacitors seem fine??
  • danielb
    Hi everyone, I have a samsung tv that keeps turning on and off.
    I pulled the bback off after researching that so many people fixed their tv by replacing capacitors but mine seem fine, no bulging or leaking residue!
    please help!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Tv turning on and off, capacitors seem fine??
    please help!
    I had several suggestions for you. Most of them involved painful self-inflicted injuries, humiliation, and death. Aspersions about your ancestry, legitimacy, and intelligence were also considered. Suggestions that you avoid posting while under the influence of recreational drugs were rejected.
    But I will try to be a nice person. Take several pictures of the back of the TV. See my signature for links to suggestions on how to do this. Attach the best picture to your next post using 'manage attachments' (below the text entry area). Include the model number of the TV.
    PlainBill
    • emil_t
      RTX3090 working fine but fans not spinning
      by emil_t
      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
      04-12-2024, 06:54 AM
    • AlexForTheWin
      Help Diagnosing ASRock Taichi X570 Motherboard
      by AlexForTheWin
      Hi all! I'm a newbie to to the forum and electronics repair in general.
      I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
      I'd very much appreciate some guidance.
      Here are the steps I've taken to diagnose the board:
      I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
      Hoping the board worked, I bought a compatible CPU on amazon. I wanted...
      12-16-2022, 11:37 PM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
    • mecha1166
      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
      by mecha1166
      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
      11-25-2024, 05:22 PM
    • netgearnetgear
      AIWA 32" TV not turning ON
      by netgearnetgear
      Good day everyone,
      I have a AIWA 32" TV model #
      AW32B4SM that is turning ON with a blank screen. The backlight is working but there is no image on the screen. I did the standard troubleshooting checks: logic board inspection under microscope, reseating ribbons cables, power rail checks, diodes, mosfet checks, power on and measure voltages on coils, caps, vcc, regulator checks all check good. Then I measured the panel voltage (12v present) and noticed that the VONE (approximately 30v) was missing, the AVDD (15v) was only 5v, vcc 3.3v present, vcc 1.8v present. I know when...
      10-03-2025, 06:06 PM
