LG 50" Plasma
  • Cornboats
    Dave
    • Oct 2010
    • 232
    • United Kingdom
    LG 50" Plasma
    This set came in with blown fuses.
    I've changed all four IPM's on Y-sus and Z-sus to be on the safe side.
    Powered up straight away but I'm worried about the heat off z sus ipm's.
    With digital temp probes sitting on the fins these are increasing from ambient to 40 deg c in 5 minutes. I bottle out after then for fear of the things blowing up again. IPM votage is 18.2 V.
    Now the Y-sus is running much cooler 32 deg c in 5 minutes. Ipm voltage is 16.2V.
    Has anyone got a working set on the bench to check temperatures for me. If not a 50" a 42 " should tell a similar story.
    Also- connected an old analogue scope with x10probe to check wave forms. Can't seem to get anything like manual says I should.
    Anyone have advice about scoping plasmas would be appreciated.
  • PowerAmpFreak
    • 982
    • Sweden
    Re: LG 50" Plasma
    When you say "IPM voltage" is 18.2V - is this verified according to levels in the service manual?
    What picture do you have when you measure the temps? I would expect the Y-SUS to dissipate more heat when there's a bright picture. Could you measure the power drawn from the mains aswell.
    Normally, in my experience, the Y-SUS heatsinks is most of the time hotter than the Z-SUS. Not much of a help, but more a clap on the shoulder!
    • cadiman
      • Mar 2010
      • 397
      Re: LG 50" Plasma
      I have had y board ipms running at 140*F. The Z drive was always cooler, but I would expect it to run around 80 to 100*F on the L/Gs
      I have had transformers on power supply boards running at 120*F
      You may need 300 mhz scope for plasma. I found a used one for 150.00
      I have a good 100mhz scope and it is hard to chase down waveforms on some of these.
      • Cornboats
        Dave
        • Oct 2010
        • 232
        • United Kingdom
        Re: LG 50" Plasma
        Thanks for your reply.
        The 18v was taken off the back of the boards.
        ref 6871qzh044c-z sus
        ref 6871 qyh039c-ysus
        Its a puzzle to me why the Y-sus is 16.2V and is running cooler than the z-sus which I've re-read at 18.2.v.Picture was normal tv programme.
        If you say the average working temp should be 80 -100f then I've got to be worried.
        40c = 104F and I've been turning set off after 5 minutes so this temp is just going to climb if I leave on.
        My scope is 50MHZ - No wonder I can't get any good pics then.
        I'll take a power reading with my amp probe and come back with info.
        • PowerAmpFreak
          • 982
          • Sweden
          Re: LG 50" Plasma
          The heat generated by driveboards are powerdissipation caused by switching losses and conduction losses of the IPM powerswitches.
          As long as you have sufficent gate-drive levels for the IPM switches, the magnitude of supply-voltage will have less effect on total heat dissipation.
          The conduction losses increase with increased power throughput and switching losses occours each time the powerswitches go from off to on and then back.
          I assume that you have already verified that all operating voltages, like Vs and Va, is properly trimmed according to the panel used and the service manual.
          • Cornboats
            Dave
            • Oct 2010
            • 232
            • United Kingdom
            Re: LG 50" Plasma
            Hi. Yes I set up vs,va,z bias, -vy and vsc as per label using dvm.
            I can't check vsetup because my 50mhz scope doesn't seem to capture the wave form .
            I took current consumption at the mains with tv picture on which is 4.2 amps based on my mains incoming at 229v ac.
            From my distant past I recall power in wattts =V x I
            therefore 229 x 4.2 =961.8 watts
            That can't be right can it? The screens only rated at 400watt-full white.
            • b700029
              Banned
              • Sep 2010
              • 640
              Re: LG 50" Plasma
              Drawing more than double the rated wattage? It sounds like something is partially shorted.
              • PlasMatt
                LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                by PlasMatt
                I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                09-20-2025, 06:50 PM
              • Salvatore057
                plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                by Salvatore057
                I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                I am lost, should I change the YSUS board? Is the YSUS board damaging...
                04-29-2018, 01:29 PM
              • JDC
                LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                by JDC
                Make and Model: LG 60PB6650-UA
                Issue: Turns on, no backlight, can hear static (no channel)
                I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                09-13-2018, 02:12 PM
              • repair-it
                Need advice testing a samsung power supply board with scope
                by repair-it
                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                07-12-2025, 11:00 AM
              • divingfe
                LG Plasma 50PA5500. Sound, no picture !!
                by divingfe
                Sorry if this is too repetitive, or in the wrong place.
                I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
                I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
                06-19-2021, 06:36 PM
