H&B drhd-120 Dvr shows split screen
  • andy smethurst
    • 49
    Hello, this Dvr produces two images on the TV screen when playing a dvd, or when using its own tuner, the screen is split down the middle and shows two images instead of one full screen image. I thought is was a tuner problem at first, but playing a dvd would not use the tuner.The twin image is not good either, its B&W and unsteady tending to vertical roll. There are no adjustments on the boards,and the power board is fine and produces the right voltages to the main board. Has anyone had this problem before? where do I start looking now? Thanks for any ideas.
    Regards:Andy.
  • andy smethurst
    • 49
    Re: H&B drhd-120 Dvr shows split screen
    fixed: I managed to find the code to do a factory reset and it came good.! I was nearly going to scrap it,as I couldnt find anything wrong with it.
    Regards:Andy.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • David82827372
      Dropped MacBookPro 15” 2012 shows black screen
      by David82827372
      MacBookPro 2012 15” A1398.
      No visual damage was found.
      Mac was inside of suitcase and it was inside of a bag.
      Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
      I tried SMC,PRAM reset, didn't work.
      Reconnecting screen display by unplugging those two things didn't work. I used this video
      Reconnecting battery didn't work.
      I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting...
      01-12-2024, 08:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
