iiyama ProLite H481S - random flickering and/or blank screen
  • BC1
    • Mar 2011
    • 6
    Hi guys! Great forum, I've done a lot of reading here the past couple of weeks but still can't seem to fix my problem.
    Few months ago, my 5 year old iiyama ProLite H481S started flickering randomly. In the following weeks, it started just going blank entirely once every week or so.
    The power LED would remain active - I would have to turn my LCD off and on to turn the backlight back on. Sometimes it would turn right back off. Hitting on the LCD (why?) would suddenly get it to work again and stop the random flickering for a week again.
    Recently, these problems have been happening almost on a daily basis. Thought it might be a good idea to see if I can repair the thing while it's still dying, rather than wait for a power surge or something bad to happen.
    So, I started Googling and came across this forum. Figured it only makes sense that capacitors lose capacity after a couple of years - wondering why I hadn't thought of it myself, as I'm studying electronic engineering and all . It could explain the problem of said flickering and blank screens.
    Opened up the monitor, inspected the caps and resistors, but seriously did not find ANY clue as to what's going on.
    So, I whipped out my camera and recorded the inverter/power-board and figured I'd post it on the interwebs, see what you guys think about it. Maybe I'm missing a clue, or maybe the board is just fine and I need to look somewhere else.
    The backside of the board is fine too, by the way. No rust, leakage or anything bad going on there.
    I didn't dare opening up the LCD unit itself (a Samsung LTM190-EX), because I'm not sure if the problem could even be in there. Can it?
    Video: http://www.megavideo.com/?v=DOE8M110
    Image: http://img849.*************/img849/4299/sam0395.jpg
    Can you guys advise me? What do yall think of the video and image I attached?
    Thanks in advance for any advise!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: iiyama ProLite H481S - random flickering and/or blank screen
    1) There are a number of reasons why we ask people to use the manage attachments function here, but I took your 5MB 4000x3000 resolution picture (good clarity and focus) and resized to fit on this forum (2000x2000 max resolution). The new file is 395KB (a 12x reduction). We also ask new members politely not to post inline.
    2) Do you have a multimeter?
    3) Caps do not have to bulge or bloat in order to be bad. They can measure incorrect uF. For example a 1000uF cap may only measure 50uF.
    --- begin sig file ---
    --- end sig file ---
    • BC1
      • Mar 2011
      • 6
      retiredcaps, thank you for your reply. I linked to a large image because I assumed people would need to see the photo in high resolution. Thank you for adjusting it to the forum rules, either way.
      Yes, I have a (cheap) multimeter. Would I have to solder the caps off before I can test them? Which multimeter mode would I have to look for to test the caps? I have not measured a capacitors F value before. I'll have a look in the multimeter manual, as well.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        A regular multimeter (even one with capacitance measurements) will not help too much with bad caps. You need an ESR meter for that.
        The good news is that you were asked for a multimeter to take voltage measurements, which your cheap meter will do just fine.
        A working TV? How boring!
        • retiredcaps
          • Apr 2010
          • 9271
          1) If you hookup a working computer with your favourite wallpaper, can you see it if you shine a flashlight on the lcd?
          2) When the lcd dies, does the power LED stay lit?
          3) Get the lcd monitor working and measure the DC voltages on CN902 for all the connectors. Be careful and don't let the probes slip to cause a short.
          4) When the lcd dies, measure the DC voltages on CN902 for all the connectors. We will then compare with the DC voltages taken in #3 above.
          • BC1
            • Mar 2011
            • 6
            @ the_unique: Great, I know how to measure voltages - let me know what you want me to measure. Keep in mind though that at this point the problem appears randomly, not constantly. It will be hard for me to measure voltages during the flickering. I want to repair it before the caps or backlight completely dies.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              I'll let retiredcaps ask these questions, he's more knowledgeable in this area and tends to have a bit more patience than i do.
              If certain points are hard to access for measurements when the monitor is working, solder wires to them and bring them outside. Be sure to label the wires and avoid shorts though. A good idea is to tape the wires to the desk.
              • BC1
                • Mar 2011
                • 6
                @ retiredcaps thank you for your guidance.
                1) Yes, it's just a backlight problem.
                2) As stated in my original post: yes, power LED stays lit after screen goes blank.
                It's gonna take a few days for me to complete step three and four. Thank you so far.
                • BC1
                  • Mar 2011
                  • 6
                  Good idea, the_unique!
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Hmm, if it happens randomly, it could be tough to get the measurements.
                    At this point, I suggest looking at all the solder joints on the backside and making sure they all look okay. If they look suspect, reflow or resolder them. Pay attention to the soldering on the inverter transformers.
                    I don't know of any multimeter that will measure ESR (ohms), but some multimeters will measure capacitance. Even then, you will probably have to desolder the capacitor to get an accurate uF reading.
                    • alexanna
                      • Mar 2010
                      • 1346
                      Also
                      If voltages appear stable, And I have a symptom of flickering of the LCD,The first thing I would rule out would be a CCFL problem most likely wiring that's effected by heat.
                      A poor solder connection on the secondary side of the inverter, again affected by heat.
                      Or an inverter coil winding that's opening up when it gets hot, you may be able to pick something up by measuring resistance cold and hot.
                      These are things I can do very quickly, and get a good idea if these are problem areas. or if I need to move on and check other areas.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Since it reacts to being hit (you brute!!!), it points to a bad solder joint, most likely on one of the leads to the CCFLs.
                        PlainBill
                        • alexanna
                          • Mar 2010
                          • 1346
                          PlainBill
                          I missed the part about the hitting monitor.
                          I have had to many problems with CCFLs,after a good visual of the board and bulging capacitors the CCFLs are at the top of my list to rule out.
                          I am lucky I can just plug in a good set of CCFLs and see if it makes a difference. There are times where the monitor has to be partially assembled to let heat do it's thing.
                          • BC1
                            • Mar 2011
                            • 6
                            Yes, it makes sense that hitting the monitor would only bring it back to life if it were caused by bad soldering or bad CCFL mounting.
                            How would you suggest to disassemble the actual LCD module (which contains the backlights)? I've been unable to find a good tutorial for it. I'll give it another Google in a bit.
                            Just a heads up, after having dis- and reassembled the monitor, the problem disappeared (for now). I do have some light flickering going on once every 3-4 days, but the display no longer goes black.
                            I'm assuming either I gave some bad soldering point (if that's causing the problem) an accidental nudge the right way, or the removal of dust on the board is preventing heat from reaching the critical levels (if that's causing the problem).
                            Thanks again for all of your help. I will keep sharing my experiences to improve our shared knowledge .
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              if you're lucky, the CCFL assembly will slide out at the side. seen that on LG-Philips panels.
                              like so
                              https://www.badcaps.net/forum/showpo...53&postcount=2
                              • mikey5791
                                Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                by mikey5791
                                Got this working ips led monitor by the brand of
                                Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                09-04-2023, 03:50 AM
                              • reessi
                                ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                by reessi
                                The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                They are black on the right and gradually fade to nothing on the far left.
                                They start either after 5 mins or up to 2 hours after so annoying for testing.
                                They flicker continuously very fast! With a slight pause milli-second every second.
                                Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                I tested each half by removing the first the left flex from...
                                06-03-2025, 09:58 AM
                              • hasel17
                                CH341a can erase and read but can't write and blank check
                                by hasel17
                                So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                Code:
                                Checking for blank...
                                (Press
                                10-26-2023, 06:20 AM
                              • Jaysean
                                Acer VN7-591G-70RT Display Flickering
                                by Jaysean
                                Hello Badcaps coummunity hope you all are having a bless day,
                                Hope I didn't post it wrong kinda new at forum site rules and tradition
                                So I'm dealing with screen flickering problem on my laptop.
                                I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                10-27-2023, 10:22 AM
                              • arctor
                                LG 55uh661v flickering images and lines
                                by arctor
                                Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                06-16-2025, 11:57 AM
