LG 50PG20 No power
+ More Options
Posts
  • waximoff
    • Mar 2011
    LG 50PG20 No power
    Hey Everyone,
    Wet behind the ears noob here.. yay! Well my problem is y LG 50pg20. About a year ago it just started turning off on its own. I would just wait a min (about as long as it took to find where my kids have hidden the remote) and turn it back on. It always came back on. The problem persisted but it would only happen every month or so. Wife and I chalked it up to overheating.
    Fast forward to last week, I wasn't around when the T.V. finally went off so I'm not sure if there was a "pop". The T.V. will not power up now, not even the the red light around the power button is on.
    So that leads me here. I searched google and most of the links came to here.
    I pulled the back off the panel and found the power supply, z and y boards. I looked for bulging caps or corrosion but could find nothing. But I cant find a fuse anywhere..
    So that's where i am. Any guidance or ideas would be more than appreciated!
  • rayrod81
    • Oct 2010
    • 205
    Re: LG 50PG20 No power
    It sounds like either the power supply or the main board. Either one could cause a dead set. I would lean toward the power supply based on the fact that the stand-by light doesn't light up. You will need to check the components (transistors, diode, mosfets, fuses, etc.) on the power supply for shorts or otherwise suspicious resistance readings. The main fuse should be near the connector for the power filter. It is the white cylindrical thing with pigtails coming off the ends. Just be aware that if that is blown there is probably more wrong with the power supply and just replacing the fuse will most likely not fix your problem.
    • zell66
      • Nov 2014
      • 35
      • usa
      I to have same problem, no power no light. is there a step by step procedure to do to figure out problem?
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
        03-31-2024, 02:12 PM
        09-06-2024, 05:59 AM
        HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
        This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-12-2024, 02:15 PM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
