Samsung LN32A550 issue
  • werthles
    • Feb 2011
    • 24
    Ok, i have had this lcd for a few months now, and i am having issues with it. When i first got it, hdmi input would yield bad results. It would turn off and not power on for weeks. When i finally tried a vga input the tv worked. It worked for a long period of time. Now, when i power it on i get a vertically distorted image and a loud static noise. If i unplug and plug it back in a couple times it works. I would have to assume that the issue with the hdmi and current issue are two seperate problems. None of the caps on any of the boards are visibly bad, although i know that that is not always the indicator. Any thoughts?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung LN32A550 issue
    The people who are able to help you here ALWAYS wants clear focused pictures so they can see what you are trying to troubleshoot.
    Remote troubleshooting is difficult enough, but without pictures, it is nearly impossible.
    --- begin sig file ---
    --- end sig file ---
    • Kjell
      Samsung Series 9 - BIOS issue
      by Kjell
      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
      08-01-2025, 09:15 AM
      09-07-2024, 05:50 AM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
    • vincentedel
      Samsung SyncMaster 740n Phase Control Issue
      by vincentedel
      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
      04-22-2025, 12:33 AM
    • Manucsl
      QE65Q800TATXXC Samsung TV Issue
      by Manucsl
      Hello.
      My TV is a QE65Q800TATXXC Samsung TV.
      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
      Any ideas to check would be very appreciated 😊
      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
      02-19-2025, 07:47 AM
