Problems with an older LG plazma TV
  • ckane
    • Feb 2011
    I have an LG 42PC1DA-UB Plasma TV. The picture had red and green dots and picture looks like an old VHS video. I checked the voltages on the power board all where set to specs printed on TV.I then adjusted the Vs voltage down 5 volts from specs. The red and green dots went away but the picture still looks like a bad VHS video on U tube. The video feed is good I had an other TV hocked to the same cable box and the picture was good. I also tried different input HDMI, Component, Cable,ECT all the same.
    Any thoughts and help would be appreciated.
    Chris
  • calrow99
    • Oct 2011
    Re: Problems with an older LG plazma TV
    Hello... any luck with fixing your LG plasma..
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • Mgiffune
      by Mgiffune
      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
      I ordered a supposedly β€˜new' Tcon board this time, and
      06-09-2024, 10:28 AM
