Visio model VX42LHDTV10A problem
  • dossman
    • Feb 2011
    • 35
    I would get the Visio logo but no sound or picture and had to unplug set to turn it off. Paid $65.00 for a service call and the technician wrote down that the mainboard was bad. I removed the mainboard and power supply board and saw no signs of overheating and 4 of the 6 680uF caps on the power supply looked a little different on the top but still looked flat when viewed from the side. I did nothing more than inspect the boards then I re-installed them. Now when I turn the set on the screen is all black, before it was lite up with a white glow but now nothing. The only thing I think I might have done was short something when I removed the three white plastic plugs from the power supply board (they were very hard to get apart and I had to use a small screwdriver to pry them apart). Could I have shorted something even though the set was unplugged when I removed the boards for inspection? I would really like to get this set going as I have an old RCA 52" Projection that the converter chips are failing on so I wanted to go to a newer TV. I'm handy with a soldering iron and have a couple of ECM weller stations and have repaired many things in the past including TV's with bad capacitors but I do not have the funds to buy every board in this set. This TV is a Visio VX42LHDTV10A Thanks to all who can help me in this matter.
  • steve2
    • Dec 2010
    • 121
    Re: Visio model VX42LHDTV10A problem
    Maybe one of those 3 connectors has a bent pin.
    • dossman
      • Feb 2011
      • 35
      I'll double check that Steve, but I'm pretty sure that all the pins lined up when I re-connected them. Thanks
