Samsung M87/86 series
  • Ludd
    • Feb 2011
    • 13
    I have an almost 3 year old Samsung TV that has just started having troubles turning itself on. Unfortunately it's an imported model, so it's not covered by the 3 year Samsung warranty.
    Since I haven't done this before, I'm wondering about caps. I've been browsing this forum for a few days and I've seen Panasonic's capacitors being recommended.
    The TV have two capacitors that look inflated, and they're rated 2200μF 10V 105C. Would any of these be good replacements?
    http://uk.farnell.com/panasonic/eca1...0uf/dp/1848535
    http://uk.farnell.com/panasonic/eeuf...0uf/dp/1800626
    From what I see these two have vast differences in life time expectancy, but also AC ripple current. Is this something I need to worry about?
    I'd very much appreciate any help!
    P.S. Below are two pictures of my power board.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Samsung M87/86 series
    here we go again... Samwha XC series
    samsung just doesn't wanna learn
    i'd replace all those light-blue Samwha caps (including the tiny ones) with equally rated Pannys. FR/FC/FM series (maybe even FL?)
    your second link points to Panasonic FR, which is OK for this purpose, but the first link is Panasonic NHG, which is a general purpose 105°C cap... not low-ESR -> not suitable for switchmode powersupplies like this one
    • Ludd
      • Feb 2011
      • 13
      Thank you for replying Scenic.
      I'll read up a bit on ESR and check the values for the rest of the caps. I think I'd like to start off by just replacing the caps that have gone bad though, since this is the first time I'm doing this, but I may as well order the rest of them in case I need them.
      I'll return with those values.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        the problem with those Samwha's is that there no datasheet on the web for the XC series. so looking up their ESR to find matching new caps isn't really possible.
        but you should be fine with panny FR/FC/FM and FL series caps as replacements for the bigger ones.
        Replacing only the obvious bulging caps is a bad idea, because the others are most likely not far behind. Also.. you're in there anyways.. much better to replace all of them now than having to open this TV up again in a couple months or so because the other Samwha's failed
        • retiredcaps
          • Apr 2010
          • 9271
          1) Agreed. If you look at the area, there is a massive heatsink that holds 3 transistors. There is a lot of heat in that area. Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
          2) Practice your soldering on old boards. If you have a friend that is good at soldering, get him/her to do it.
          3) The best soldering video is made by CuriousInventor at
          http://www.youtube.com/watch?v=I_NU2ruzyc4
          4) This site has an excellent written tutorial on replacing caps with excellent photos in the FAQ section.
          https://www.badcaps.net/forum/showthread.php?t=485
          --- begin sig file ---
          --- end sig file ---
          • Ludd
            • Feb 2011
            • 13
            Thanks for the pointers, Scenic and retiredcaps!
            So would I need an ESR tester to know what caps to replace the old ones with?
            The remaining of the larger caps have these values:
            1000 uF 25V 105C
            1000 uF 10V 105C
            • retiredcaps
              • Apr 2010
              • 9271
              Just replace them all as Scenic suggested with Panasonic FR/FM/FC series.
              The cost of an ESR meter is justified if you will be repairing more TVs or lcd monitors. Otherwise, it is cheaper just to replace all the caps.
              • Ludd
                • Feb 2011
                • 13
                Right, I've selected these for both the 25V and 10V caps -- they seem to be low ESR and in the FR series:
                http://uk.farnell.com/panasonic/eeuf...0uf/dp/1800654
                There are six smaller caps as well. Three of them are by the bigger ones by the heatsink, another three are spread across the board. They are all 47uF 50V.
                Replacements:
                http://uk.farnell.com/panasonic/eeuf...7uf/dp/1848463
                Does that look all right?
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  those are fine if 25mm high caps fit in there.
                  better check that first, or you'll end up not being able to put the cover back on.
                  been there, done that
                  • Ludd
                    • Feb 2011
                    • 13
                    There's a few centimeters of room there, so they'll fit.
                    I have one more question that irks my mind: Would it be better to go up a bit in voltage for all capacitors than to stay at the exact value of the original caps?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Going up in voltage is fine, but remember the higher voltages caps could be bigger in diameter or height.
                      For spares/extras, I will typically order the larger voltage cap if the diameter and height are the same size. For example, if a 1000uF 10V and 1000uF 16V cap are the exact same size, I will buy the 16V cap because I know it can be used in on a 5V rail and 12V rail whereas the 10V cap can only be used on a 5V rail.
                      PCBONEZ talks about all this is great detail at
                      https://www.badcaps.net/forum/showpo...30&postcount=7
                      • PlainBill
                        • Feb 2009
                        • 7034
                        For this application, it would be OK, but not better. As retiredcaps points out, higher voltage, same size caps provide a more versatile spares stock.
                        Remember, the original caps didn't fail due to excess voltage, they failed due to poor quality.
                        PlainBill
                        • Ludd
                          • Feb 2011
                          • 13
                          Thanks again guys, I'll report back once I've received and soldered the new caps.
                          • Ludd
                            • Feb 2011
                            • 13
                            Well I'm back. Had some trouble ordering the capacitors, turns out that Farnell won't sell to anyone but companies.
                            It also turns out that ordering capacitors where I live is rather expensive. So I opted for replacing just the capacitors that look bad, and go from there.
                            I ordered Rubycon capacitors in the ZL and ZLH series. Both for my TV and my broken Samsung PC monitor. Any thoughts on these? I had trouble finding info on some of them:
                            TV:
                            Rubycon 16ZLH2200MG412.5X20 2200uF 16V
                            Monitor:
                            Rubycon 25ZL680M10X20 680uF 25V
                            Rubycon 50ZL330M10X23 330uF 50V
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Both ZL and ZLH are on the good list at
                              https://www.badcaps.net/forum/showthread.php?t=2280
                              They are not as low ESR as the MBZ or MCZ though.
                              PCBONEZ talks about choosing the right caps at
                              https://www.badcaps.net/forum/showpo...47&postcount=3
                              and explains more at
                              • Ludd
                                • Feb 2011
                                • 13
                                retiredcaps,
                                Yeah, that's pretty much why I chose them. Would've gone for lower rated caps if I could, but I had trouble finding any.
                                I'll have a look through your links, thanks.
                                • Ludd
                                  • Feb 2011
                                  • 13
                                  Hey again,
                                  Thanks for all the advice and help guys. I fixed the TV.
                                  The soldering iron I had borrowed wasn't the most fun to use: it was rather hot to hold and had awkward heat distribution, but it worked.
                                  One last thing that's on my mind is whether the solder wire I used have any flux in it and I need to use off-flux. I can't seem to find any info on it, it's a "velleman 60/40 Rosin Core".
                                  [Edit] So apparently rosin is a type of flux. Wikipedia says cleaning is optional but preferred. Any thoughts?
                                  • Ludd
                                    • Feb 2011
                                    • 13
                                    Okay, a few more concerns:
                                    1. I added a bit extra solder to two joints after soldering them. Since solder only reacts once, may these become "cold" joints and should I redo them completely? I don't think I melted the solder from the first round completely when I added more.
                                    2. I used desoldering braid removing the original factory soldering. Those have flux as well apparently. Again, do I need flux-off and how quickly do I need it, or is it as Wikipedia says optional?
                                    • Scenic
                                      o.O
                                      • Sep 2007
                                      • 2642
                                      i usually don't clean it.. never had a problem so far.
                                      Isopropyl Alcohol also works fine for removing flux residue. no need for fancy flux removing gimmicks..
                                      • Ludd
                                        • Feb 2011
                                        • 13
                                        Alright, thanks a lot Scenic! Any thoughts on the joints I added solder to?
                                          09-07-2024, 05:50 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • Biruslapio
                                          Samsung's AU series "high quality" panel internally melting
                                          by Biruslapio
                                          I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                                          I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                                          07-12-2024, 10:08 AM
                                          ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                          ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
