Samsung SP-P4251 Plasma No power
  • Hornnumb2
    • Feb 2011
    • 218
    I have a plasma that does not power up, it gives a start up sound and 5 blue ring flashes but then shuts off. I have soldered new caps in my moms samsung lcd but this plasma is different. Any ideas where to start, I have a multimeter and can solder. Thanks Michael
  • rayrod81
    • Oct 2010
    • 205
    Re: Samsung SP-P4251 Plasma No power
    If I were you I would start by disconnecting the Y-Main and X-main from the power supply one at a time and trying to power it up. If it stays on at power up then it will most likely be the board that is unplugged from the power supply. If it does not stay on at power up with the boards disconnected then it is most likely the power supply. Keep in mind these are just blind suggestions. Clear pictures of the power supply, Y-Main, and X-Main will be needed to get you going in the right direction.
    • mbates14
      • May 2005
      • 169
      the 3077s go bad in the sustain module.
      50/50 shot it takes out the Vs transistors in the power supply bd as well.
      going off memory, but if it serves me, there are two 2SK23XX? i cant remmeber. but they go, they take out the IR2114 and take out the fuse with it.
      this happens sometimes, alongside the 3077 failure.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • CDNBrewer
        Samsung Plasma PN43D450A2D No Power
        by CDNBrewer
        Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
        This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
        I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
        When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
        03-02-2025, 04:59 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • lp20th
        Samsung Plasma TV Power Supply Issue
        by lp20th
        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
        11-28-2023, 10:28 AM
