What is a y sus
  • handyman
    • Jan 2011
    What is a y sus
    What does the y sus board do in a plasma TV. My TV has vertical lines and no real picture. Do I need to replace that?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: What is a y sus
    See Coppell TV Blog
    http://blog.coppelltvrepair.com/2010...-lines-in.html
    --- begin sig file ---
    --- end sig file ---
    • tencom1000
      • Jun 2011
      Re: What is a y sus
      Coppell tv repair. Go there. They offer great advice. and they don't charge you for that. This is rare in business today. I read their advice on the the YDRVboards and it is accurate. I've tested and replaced 2 of them on my 50" plasma, Fixed my problem for the cost of the boards andmailing. ($37 each board.) I first replaced the bottom board, then the top went bad about 1 week later. i replaced it and BINGO! it has been working good for a couple months now. I only now heard about their blog. I am impressed. Straight advice.
      • Wizard
        • Mar 2008
        • 2296
        Re: What is a y sus
        Vertical lines has nothing do with the YSUS. This is either LVDS cable, logic board, the mainboard or worse, panel.
        Cheers, Wizard
        • japlytic
          • Oct 2005
          • 2086
          Re: What is a y sus
          A related question, what is a Z-sus?
          • CoppellTVRepair
            • Dec 2010
            • 39
            Re: What is a y sus
            Cheers, Wizard
            This is, of course, incorrect statement as the following article and, specifically, the picture in it proves:
            A shorted cap or resistor at the YSUS power output line would result EXACTLY in a vertical line as I have witnessed a few times; a shorted buffer would have the exact same effect.
            Granted, a shorted buffer is a whole lot more common than a shorted capacitor at the YSUS output...and yet I've seen that too and it is simply incorrect to say that vertical lines can't be caused by YSUS.
            It is unlikely yet certainly not impossible.
            Thanks to everyone for the kind words!
            • ArMaaN376
              Samsung PS51E550 Plasma TV
              by ArMaaN376
              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
              Opened TV cover & observed foll
              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
              How to confirm Y -Buffer board...
              06-19-2024, 04:05 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • Jidis
              Need T-Con Advice (Vizio P602ui-B3)
              by Jidis
              I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
              He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
              09-22-2025, 05:10 PM
            • zlr8r
              Advice on newer EC chip programming eg. MEC5107-LJ BGA
              by zlr8r
              Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
              i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
              09-16-2025, 09:54 AM
