42LG5010 psu caps
  • Blueaardvark46
    • Jan 2011
    • 6
    • Wales
    42LG5010 psu caps
    I've got a LG 42LG5010 tv here and I'm in the middle of replacing all the electrolytics on the psu board EAY4050520. I took them all out and wrote down all the circuit reference numbers and corresponding values. I then ordered those
    which I didn't have in stock but when I was ready to put them all back in I found that the paper had disappeared and now I have bundle of new caps and
    don't know in which position to fit them. Does anybody have a circuit diagam
    for the panel or maybe one of you out there has a similar one and could have a
    look at it and tell me where each value should be. I would be most grateful.
    John.
  • pagy snv
    • Nov 2009
    Re: 42LG5010 psu caps
    Hello i have this board by me for repair so when you need to know the values and positions then write me back.
    Bye.
    • marshall361
      • Feb 2016
      • United Sates
      I also have the 4050520 power supply and was wondering where you got the caps and if it fixed tv. Mine is blinking and sometimes does work, but then just shuts down periodically and takes an hour or so to power up. I measured caps out of board and seem to be ok, but going to replace all 18 and see if it fixes it. Any help appreciated. Thanks
      • Ruts
        PS5 EDM-033 Caps values near Southbridge
        by Ruts
        Hi
        I managed to knock off two capacitors on a EDM 033 board near the southbridge and BIOS chip.
        Does anyone know the values of these capacitors?
        09-15-2025, 06:00 AM
      • briztech
        identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
        by briztech
        Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
        07-25-2024, 06:18 AM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
