Samsung LN-T3242H power supply
  • zachn
    • Nov 2010
    • 23
    Re: Samsung LN-T3242H power supply
    I took another look at the back of the board and found a burnt resistor at RP817, removed it and it tested open. i dont have my camera with me to take a picture, however I found a schematic. I am not sure what type of resistor that is, can you help me find the correct replacement? thanks!!
    • zachn
      • Nov 2010
      • 23
      I also have a bn44-00173a that i have for spare parts. If i could found out the top number value, I could pull one off the 173a board.
      • PlainBill
        • Feb 2009
        • 7034
        Well, it would appear to be a 6.8 ohm resistor in a 2012 package. I'm not sure what J stands for.
        Because of it's location, I would also check DP814, DZP801, and QP801S.
        PlainBill
        • zachn
          • Nov 2010
          • 23
          So the code on top of the SMD should be 6R8?
          • zachn
            • Nov 2010
            • 23
            and do you think a 4R7 would work in its place?
            • PlainBill
              • Feb 2009
              • 7034
              Let me answer your question by asking another. Let's assume you are a rather well proportioned male who wears jeans with a 32" inseam, 34" waist. Would you be pleased if your wife bought you a pair of jeans with a 38" inseam, 24" waist?
              Changing values in the gate drive circuit of the main power FET is a good way to blow more expensive components, such as the main power FET.
              PlainBill
              • zachn
                • Nov 2010
                • 23
                #27
                Im having trouble finding the correct part on mouser.
                • PlainBill
                  • Feb 2009
                  • 7034
                  I believe they package is the metric designation. J would indicate a 5% tolerance. They appear to have them on Digikey, P6.8CECT-ND.
                  Did you check the other components associated with this resistor? It is very unlikely this resistor would fail unless some other component also failed.
                  PlainBill
                  • zachn
                    • Nov 2010
                    • 23
                    #29
                    nice find!
                    I did check the other components and QP801S was the original shorted component and that has been replaced. however I will order a new one because I used that FET from an older board I had around. DP814 and DZP801 tested OK in circuit.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      nice find!
                      Good work. Odds are the resistor smoked when the FET shorted.
                      PlainBill
                      • zachn
                        • Nov 2010
                        • 23
                        #31
                        The power supply appears to have four output connectors. Typically these connectors have a legend that indicates the function of each pin. You would be looking for a pin labeled something like On , Power on, On/Off, etc. The voltage at that pin would be a good start.
                        Of course, good pictures of the bottom of the supply would help, as would pictures of the legends.
                        PlainBill
                        Unrelated.
                        what should the voltage be on the on/off pin?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Unrelated.
                          0 volts for off, about 3V for On. One source suggested using 2 AA batteries to supply 3.2 volts, I'd try using a 1K resistor from 5V standby to the ON pin.
                          PlainBill
                          • zachn
                            • Nov 2010
                            • 23
                            #33
                            i got the new parts on the board, its not shorting out but it wont power on. I am just getting the red standby light and it will flash every once in a while. at the moment i am stumped.
                            • zachn
                              • Nov 2010
                              • 23
                              #34
                              since i was stumped, i plugged the board in and took some voltages. while i was doing that the IC at ICP801S got so hot it started smoking and almost took it self off the board. before i order the new chip, is there something else that could cause that chip to fail? thanks.
                              • zachn
                                • Nov 2010
                                • 23
                                #35
                                i was also getting about 60v at the points shown on the pic. does that seem high?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Not necessarily. That is in the Hot (or Live) ground area. Use the negative lead of CP803? (150uF, 450 V) as the ground point, not the chassis.
                                  PlainBill
                                  • eotto05
                                    • Oct 2011
                                    #37
                                    I have a samsung LN-T3242H that keeps blowing the fuse on the power supply board. the power supply board is model BN44-00192A. nothing on the board has any visible sign of damage. does anyone have an idea of where to start troubleshooting? Thanks!
                                    I have the same model tv that I got from my sister she told me when the picture went out you would still be able to hear sound but I have yet to hear sound when I attempted to troubleshoot when I turn on the set no picture no sound I've tried hooking up cable figured it would automatically detect and maybe I'd hear sound but the red light in front of tv does come on an thats about it Im assuming ins the inverter but im unsure any suggestions?? would be greatly appreciated thanks...
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                      by sam_sam_sam
                                      07-01-2024, 06:34 AM
                                    • cheeky2
                                      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                      by cheeky2
                                      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                      06-15-2025, 05:12 AM
                                    • JimBanville
                                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                      by JimBanville
                                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                      09-13-2023, 07:21 AM
