Spectroniq PLTV-3250
  • tjjc00
    • Dec 2010
    I have a Spectroniq PLTV-3250 that is missing the 5 volt side of the power supply. I was following a post by plain bill but never seen him again after the first few post any help please
  • PlainBill
    • Feb 2009
    • 7034
    Re: Spectroniq PLTV-3250
    In the spirit of the season I will NOT tell you my opinion of those who cannot take instructions. A simple search on PLTV-3250 brings up 5 hits. One is this thread. Another is a thread in which retiredcaps suggested using the search feature.
    IF you had done so, you would have found a long thread which gives a lot of information on repairing the power supply. You would also have found a shorter thread which also has some information, as well as another thread which mentions similar problems on a set that uses the same supply. Somewhere in those three threads it mentions that the power supply is available on eBay. Instead of following retiredcaps advice, out of some misguided perversity you started another thread!!
    NOW, if you are actually interested in getting your TV working, I will point out that buying a complete power supply may be the easiest way. If you wish to repair yours, I will help. First, read the links in my signature on the suggested way to take and attach pictures. Attach good, clear pictures of the top and bottom of the power supply to the long thread I linked above. I will reply when I have free time. Because of my plans for today I may not be back here today.
    PlainBill
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
