Digital Lifestyles LT42322 FA2B-42323 LCD TV No Picture
  • 70JUDGE
    • Jul 2010
    • 81
    I have Digital Lifestyles LT42322 FA2B-42323 LCD TV that turns on,but doesn't show a picture.
    I changed both the master,and slave inverters because they both had bad components,and that didn't make any difference.Did I get a bad inverter?
    All the voltages on the power supply measure above what they are marked,except the 12V,and that shows 11.72V.Is that enough?How much can the voltages vary,and still be alright?
    Would a bad LCD controller prevent the TV from showing a picture?
    I also noticed a high pitch noise coming from the power supply when the TV is off,but it goes away when it turns on.
    Any help is greatly appreciated.Thank You very much!
    Tyler
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Digital Lifestyles LT42322 FA2B-42323 LCD TV No Picture
    That low 11.7 volts may be enough to trip the under voltage protection. It may be capacitor related.
    • crepiduse
      • Nov 2010
      • 69
      I'm going to suspect cap problem, however, please follow PlainBill's picture guide in one of his signatures and post pictures of all the boards and model numbers. Remember to use manage attachments and also resize to 2000x2000 pixels. This will aid in helping you.
      • 70JUDGE
        • Jul 2010
        • 81
        Turns out I had replaced the bad original master inverter with another bad inverter I had bought for another like TV.That inverter must have a problem other then bad capacitors,transistors,or IC chip I can't see.I ended up using the original master after replacing the capacitors,and the slave I had originally bought for the TV.Thank You all very much for all of the help!
        Tyler
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • CyberPhoenix
          Issue with picture quality of Sony bravia TV
          by CyberPhoenix
          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
          01-22-2024, 02:08 AM
