LG LCD 37LC2D - diagonal/fuzzy lines
  • retiredcaps
    • Apr 2010
    • 9271
    HISTORY
    This is my friend's LG 37 inch LCD TV 37LC2D. It was made around Sept 2006. It has been working fine until recently when the display started looking like the picture attached when watch cable TV.
    MEASUREMENTS
    None. I do NOT have access to this TV to take any voltage measurements. The TV is at his house and I don't live close to him. He doesn't have a multimeter and does not know much about electronics.
    PICTURES
    I convinced him to open up the TV and take pictures. He works night shift and sleeps during the day so the pictures aren't the greatest, but I see no bloated caps and neither does he.
    SERVICE MANUAL
    The symptoms of the TV look like page 22, but unfortunately, I can't do any of the troubleshooting steps outlined. Manual is at
    QUESTION
    So given the lack of access to the TV, what would be your best guess as what is wrong? And yes, I realize this is a "garbage in, garbage out" scenario. He may consider re-opening up the TV and letting me have a more in depth look at a future date.
    edit: I'm hoping this TV is old enough that people have dealt with this issue before?
    --- begin sig file ---
    --- end sig file ---
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG LCD 37LC2D - diagonal/fuzzy lines
    Originally posted by retiredcaps
    HISTORY
    MEASUREMENTS
    PICTURES
    SERVICE MANUAL
    QUESTION
    The first line raises a question. You said the problem occurs "when watch cable TV". How about when they are using one of the other inputs? What do the menus look like?
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      He just tested a DVD and says the problem exists as well. He then went on to test all inputs and the same thing. He doesn't use his DVD much, just watches cable TV sports.
      The lines also appear when the TV menu setup button is pressed.
      He says sound works fine, but lines cover the rest of the screen. He can make out shadows of people (like sports desk commentators).
      • PlainBill
        • Feb 2009
        • 7034
        TCON or panel.
        PlainBill
        • retiredcaps
          • Apr 2010
          • 9271
          TCON or panel.
          Thanks PlainBill. That is what I was thinking as well, but I wanted someone to confirm/verify.
          I'll see if he is game to reopen the TV and get a part number for the tcon. From my initial research, it looks like the tcon board is fairly generic and used in other non LG TV models.
          It looks like the tcon is around $30 to $50 USD. I'll let him make the financial decision as to proceed or not with a tcon replacement.
          • retiredcaps
            • Apr 2010
            • 9271
            After some patient ebay watching, I bought the t-con from a USA seller for a reasonable price and shipping to Canada.
            It arrived Christmas Eve, gave it to my friend on Christmas Day, and he reports today that the replacement t-con has fixed his TV.
            When searching for 37lc2d on the Internet, I found that many sellers listed this with the description 6870C-0060H. So I switched my search criteria from 37lc2d to 6870C-0060H. This listed several more lower cost optons and I noticed that this board is used in many other TV lcd models (RCA, Olevia, Syntax, Mintek, Sharp, Vizio).
            My friend says to PlainBill. Thanks PlainBill for helping on this.
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • jeyoung12
              Samsung QN50Q60t lines on screen
              by jeyoung12
              Hi all
              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
              So....i don't know what end of the C ribbon to work with...
              02-26-2024, 10:38 AM
            • ggil44
              Sony XBR-65X750D Horizontal lines bottom of screen
              by ggil44
              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
              05-30-2023, 07:51 PM
            • visionbluedemon
              Help. Sony kd-65x85dj vertical lines
              by visionbluedemon
              First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
              Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
              tried blocking LC lines too, but same results
              is it lcd panel issue or tcon board issue?...
              Yesterday, 04:56 AM
