Sharp lc32sh20u rare problem
  • fastvideo
    • Dec 2008
    • 55
    TV mode: no video,no sound.
    Input 1 (composite): have video, no sound.
    Input 2 (composite): no video, have sound.
    Input 3 (component): have video, no sound.
    Input 4 (hdmi): have both video and sound.
    Is this a really rare problem?
    Any help here?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sharp lc32sh20u rare problem
    Any help here?
    Sounds like a problem with the IC that selects the input. Unless you can find a bad power voltage regulator on the board, it will probably require replacing the appropriate board. The service manual is available on elektrotanya.
    PlainBill
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      yep a source switching problem.likely got zapped through the inputs.
      • fastvideo
        • Dec 2008
        • 55
        Thank you for the advise, will look into it later.
        I have the service manual.
        Flash memory is on scaler board if the tv has a corrupted firmware.
        Problem with the IC that selects the input is on AV board.
        This is very tough call to me, 50/50 chances of these two board.
        I have a feeling that may be the firmware was corrupted.
        If anyone have copy of this firmware please let me know, thank you.
        • Wizard
          • Mar 2008
          • 2296
          Sounds more like corrupt firmware.
          If you get working input at all, that is not the chip. Especially if the chip got clobbered, IC tend to die totally and give nothing at all. And double especially on generic TVs, they tend to use all in one IC to keep cost down. Usually Mediatek. (Yuck).
          Cheers, Wizard
          • fastvideo
            • Dec 2008
            • 55
            • mbates14
              • May 2005
              • 169
              and thats the thing you wont find. becuase i never have. unless the manufacturer has firmware updates on thier website.
              • fastvideo
                • Dec 2008
                • 55
                I think I am go for the scaler board.
                After looking at the service manual, look like IC801 AND PERIPHERAL CIRCUIT is problem.
                • fastvideo
                  • Dec 2008
                  • 55
                  Got another scaler board installed, no luck.
                  Now I am looking for IC4201.
                  • fastvideo
                    • Dec 2008
                    • 55
                    Defective IC4201 confirmed.
                    Replace a new one, TV is working again.
                    • malicegreene
                      • Jan 2011
                      i had to register to this forum just to say i have this SAME problem ....
                      i'm going to take your advice and replace this "IC4201" piece ...
                      if this works .. thanks a million ...
                      • malicegreene
                        • Jan 2011
                        also ... where did u get the IC4201 piece ...?
                        and what kind of directions did u find to replace it ... ?
                        can i just pull off the back of the tv and match the pieces ... in order to see which on to replace ...
                        any help would be greatly appreciated ... thanx...
                        • fastvideo
                          • Dec 2008
                          • 55
                          IC4201 is a 36pin SMD type IC. I have to remove it with hot air and spent quite some time to put back the surrounding SMD components.
                          Warning:
                          This job is not recommend for newbies.
                          Replace the complete AV board is more safe and easy job.
                          • malicegreene
                            • Jan 2011
                            any recommendations where to get the board... ?
                            been trying google ...but nothing ....
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Someone on eBay is selling a set of 6 boards.
                              PlainBill
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • Christos Tsiligiannis
                                Marian Trace Alpha sound card repair help
                                by Christos Tsiligiannis
                                Hello to the forum.
                                My name is Christos, I am new to the forum here and i am posting from Greece.
                                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                11-18-2024, 05:26 AM
                                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:30 PM
                                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
