I cracked my panel on my 50S421 replacing backlights and I found a tv online I'd like to use as a donor if possible. The model in question is a 50S434. They are both in the 4 series and obviously both are 50". Does anyone know if the panels are the same or close enough? The only difference I see is one is Roku and the other is Android TV.
TCL 4-Series Panel Swap?
Tags: None
Re: TCL 4-Series Panel Swap?
I don’t think it’s compatible. Also there are several versions of these TVs that use different tcon boards between them. -
If I can get this tv cheap enough it might be worth it to swap the panel and the boards into the other one with new back lights. That is if the mounting holes are the same.
I don't see how it's cost effective to make 7 different versions of the same tv using all different part configurations
I just checked ShopJimmy and apparently there is a 421 WITH a TCON and one WITHOUT it. I have the LDAA which has one, so I guess they're not compatible.Last edited by x_orange90_x; 11-15-2023, 07:10 AM.Comment
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by iglitareHi,
Or is it always a bad/shorted... -
by Lee M.TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
- Loading...
