Philips 22HFL3232D/10 hotel unlock?
    Hello. Got this tv with limited functions and with guest remote. Security level is probably on most high, i tried all posible codes like 319753info etc, nothing work! I tried upgrade firmware via usb, nothing happens. I dont have master remote to turn this hotel mode off, cant find one anywhere.. Is there any way, lets say to use universal remote and will it be able to enter setup menu? Is there windows program which can emulate it true ir sensor? I'm even thinking of upgrading firmware on cmos chip (like on pc mbos) with CH341A programer but firmware is pkg file (PS_2K10_DL_BUH-EU_MT5363_panel_2.02_110704_upgrade.pkg) and im not even sure its posible to unpack it and use this method? Any way around? Thanx all
    Re: Philips 22HFL3232D/10 hotel unlock?
    I got universal philips remote which have ~8 philips presets. "setup" key on remote is not working. There is some function like audio, display mode (cinema etc) that is not available on guest remote but no setup menu Why its so hard to reset it to default or to access setup? No way around?
      here is the manual ..start at the beginning . https://www.manualslib.com/manual/50...?page=9#manual
        319753 is not working.
        "Note: The sequence: 3, 1, 9, 7, 5, 3, 'MUTE' will not show the Setup Menu if High Security Menu is enabled. (See. Page 20)"
          Try combination from LC43HELA - 024995 Menu , maybe will help. Setup remote is RC2573 .
            Not working. Thx
              You need to use RC2573 .You can use learning remote Venus , Superior , or Classisc .
                Do you mean to use one of this eg Superior to Copy RC2573 remote? So i need also RC2573 which i cant find?
                This 'Superior' remote is what i can find in my country
                  Philips SW Linux ....no need special RC... android IR apk with smart mobile had ir sender enough... also mini usb air keyboards with F funktion do better than original RC
                    http://www.telecontrol.tv - with this remote .
                      My tv model is not smart tv, no wireless etc.
                      Are you refering to this one? Are you sure it will work?
                        what i wrote above had nothings to do with Internet or Smart TV... apk on android device with IR will work like RC, and wireless mini keyboards also had nothings to do with internet.. its same when you use air mouse on PC but this keyboards.
                          This one , from ASWO .
                            Used my old LG G2 mini with built in IR. Most of app's are not working, and built in app work but cant access rc5 setup menu..
                            Cant find this Superior remote in my country.
