Telefunken 55" Model TLEDD-55FHDA (bad picture)
  • angelos
    • Dec 2012
    • 562
    • South Africa
    Hi Guys,
    Its the second time i have come across this same issue in the last month and having to give back the sets unrepaired does not pay the bills. That said i was asking for a second opinion on this fault.
    The image manifests with a lot of lines horizontally at the top and bottom of the display and after a while colors spread all over the screen. A lot like a VGH, VGL, AVDD issue etc.
    I am going to explain with photo's what I have seen in separate posts after this one.
  • angelos
    • Dec 2012
    • 562
    • South Africa
    Re: Telefunken 55" Model TLEDD-55FHDA (bad picture)
    Here is a picture of the main and TCON
    • angelos
      • Dec 2012
      • 562
      • South Africa
      I measured around the TCON and found all the voltages to be correct.
      VGH = 25.8
      VGL = -6.2
      HAVDD = 7.8
      VCC1 = 3.3V
      VDD18 = 1.78
      The CKV and CKL lines i am not sure of.
      On the next lot of photos i will show you how the image starts off and worsens.
      Photo 20231111_141917.jpg is when the set is switched on initially
      and photo 20231111_140411.jpg is after one minute of running
      • angelos
        • Dec 2012
        • 562
        • South Africa
        On the TCON connecting to the panel there are two ribbons if i disconnect the right side ribbon i get.... check photos
        • angelos
          • Dec 2012
          • 562
          • South Africa
          If I reconnect the ribbon and change to the other side the results are the same as in the photo's except in it's the other side now. Taping off the CKV and CLK lines makes no difference.
          My question is, TCON or Panel???????????????????
          I have a oscilloscope and can take waveform measurements to diagnose if someone on the forum has experience on this kind of issue.
          I wish i knew how to force the TCON into aging mode to exclude main board issues but i dont know how to. It;s a chinese secret.
          • EazyBone
            • Jun 2023
            • 1303
            • United states
            With some tvs, you can disconnect the main board and tcon and put 12v on the fuse jumpered from a 12v line. On some tvs this will cycle picture as a full solid color. Research before you do this but works on some sony and Hisense you then would see if those lines still exist and would know tcon or panel.
            • angelos
              • Dec 2012
              • 562
              • South Africa
              I did unplug the LVDS cable entering the TCON and used a external 12V PSU to power the panel. It came up blank. I tried doing research on the TCON on how to force the burn-in or aging mode but found squat.
              • arizanotlari
                • Nov 2014
                • 158
                • Turkiye
                For Fhd : Apply 3.3V to pin-44.
                51 50 49 48 is panel vcc
                7. Specific pin No. #44 is used for “No signal detection” of system signal interface.
                It should be GND for NSB(No Signal Black) during the system interface signal is not.
                If this pin is “H”, LCD Module displays AGP(Auto Generation Pattern).
                https://www.badcaps.net
                • angelos
                  • Dec 2012
                  • 562
                  • South Africa
                  Thank you for your response Arizontlari.
                  I need to fully understand what you are explaining to me.
                  1. When applying 3 3V to pin 44, are you talking of pin 44 of the big square IC in the middle of the tcon?
                  I only have one power supply which can feed the panel voltage (12V) to the tcon. Should I look on the tcon for a derived voltage? A 3.3V rail?
                  2. You said pin 51 50 49 48 is panel vcc. Which pins are we talking of? The LVDS feed cable or the big square ic in the middle of the tcon?
                  3. Do you have literature or a datasheet on the chip that I can study?
                  Thanking you in advance
                  Angelos
                  • angelos
                    • Dec 2012
                    • 562
                    • South Africa
                    After meditating on what you said I drew on the picture a white line representing what I understand from what you said. Have a look at the picture.
                    On the right of the tcon next to the lvds connector is a plug cut out on the pcb. The pin on the far right seems to be labeled 3.3V. I must just check what grounds pin 44. Pin 44 is also connected to pins 46 45 and 39.
                    • lotas
                      • Jan 2016
                      • 4458
                      • Russia
                      39, 44, 45, 46 - gnd
                      • angelos
                        • Dec 2012
                        • 562
                        • South Africa
                        Please help me understand. Have a look at the photo I have attached and check the comments. I don't understand where to apply the 3.3V to force chip into test mode.
                        • angelos
                          • Dec 2012
                          • 562
                          • South Africa
                          I checked further and found a group of resistors. Please check the photo.
                          If I study that circuit then currently pins 3 and 4 of the KIWIMAGE (KV7626) chip are at a zero potential because R28 (4K7) pull down resistor and R26 (4K7) pull down resistor force these pins to a logic zero. Those other spots where no resistors are installed namely (R23 and R21) are where i bridge it out to add the 3.3V supply to the chip
                          I have done it logically,
                          Pin 3 Pin 4 Result
                          Logic state 0 0 Blank image
                          0 1 Blank image
                          1 0 Blank image
                          1 1 Blank image
                          So, no luck. Any comments?
                          • arizanotlari
                            • Nov 2014
                            • 158
                            • Turkiye
                            According to LG standards, the 44th leg is used for AGP, but in some TCONs this leg is used, while in others it is used as gnd.
                            Unfortunately, AGP cannot be activated because this leg is grounded in the tcon in question.
                            • angelos
                              • Dec 2012
                              • 562
                              • South Africa
                              All right, so you are saying it cannot be tested on my TCON design.
                              Just to clarify things, when you are talking of LG standards are you referring to the TCON. Is this an LG design TCON? So the LVDS plug follows a certain standard pin layout on some TCONS?
                              • arizanotlari
                                • Nov 2014
                                • 158
                                • Turkiye
                                Didn't you know this? Some of the 51-pin lvds have 3, some 4, and some 5 supply pins. These (in my opinion) set the standard of LVDS. If you examine the schematics of TVs of different brands (Samsung, LG, etc.), you can see the differences.
                                • angelos
                                  • Dec 2012
                                  • 562
                                  • South Africa
                                  I have never seen a single tcon schematic. It seems it's a bloody chinese
                                  secret
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • samtron786
                                    Telefunken Model: D32F289M4CWI has sound but no picture
                                    by samtron786
                                    Hi
                                    Telefunken Model: D32F289M4CWI has sound but no picture, I checked 2 LED strips, they are all OK after the TV has been switched on, a short flash occurs and stays on but no light or picture with a flashlight can I do something see
                                    The power supply is VESTEL 17IPS62
                                    Vestel 17 MB 211S Mainboard
                                    Many Thanks
                                    03-01-2021, 05:00 AM
                                  • Fripacks
                                    No picture LG model 50PT350
                                    by Fripacks
                                    Hi guys,
                                    I have problems no picture with LG model 50PT350, first of all, I change the 2 buffer boards who was no good, the TV working 2 weeks and today same problem, I check and I found Zsus board defect now, I change it for a new one and no picture, I check VS VA and 5 volts , all this voltage are there, I disconnect the upper buffer board, no picture, I disconnect the lower buffer board, no picture, what I have to check now?...
                                    05-19-2023, 12:06 PM
                                    HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-06-2024, 05:27 AM
                                    HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                    This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
