Sony Bravia 65x900F BL On but not picture
  • lmcancu
    • Oct 2009
    • 158
    I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
    I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and they show the correct voltages: 3.3v, 12.45v, ~38V, etc for each LED. I also removed the two ribbon cables between the t-con board and the CPU with the same result. What is my next step?
  • alfatv
    • Sep 2020
    • 353
    Re: Sony Bravia 65x900F BL On but not picture
    When you say half screen, was it sharp divide or gradual transition?
    Please remove cover from t-con, that would be the next thing to try.
    • EazyBone
      • Jun 2023
      • 1327
      • United states
      TCON controls each half of the screen. So probably a tcon issue or panel issue. Find which side ribbon corresponds with the black side screen, as we can't see from picture and test the voltages coming from tcon to buffer boards, and search buffer boards for shorts.
      Looks like picture shows you have all backlight so that's probably not the problem since we don't have a pic of the screen.
      • lmcancu
        • Oct 2009
        • 158
        It was a Sharp divide I think, when I first came back from the washroom, I could only see half of the youtube screen. But then it seemed like youtube was then fully only on half the screen, but I am unsure. The measurements from the connectors on the power supply board are:
        12v(LD): 12.6v
        NC
        GL_Ctrl: 1.6V
        SENSE_GND: 3.3V
        VLED_GND: 2.2mv
        VLED_GND: 2.2mv
        VLED_GND: 2.2mv
        VLED_GND: 2.2mv
        NC
        VLED_VCC: 38.3v
        VLED_VCC: 38.3v
        VLED_VCC: 38.3v
        VLED_VCC: 38.3v
        BL_ON: 3.3v
        GND
        GND
        GND: 2.9 mv
        REG 12V: 12.66V
        REG 12V: 12.65v
        REG 12v: 12.65V
        GND: 2.3mv
        GND: 2.3mv
        GND: 2.5mv
        TCON_ON: 3.3B
        TCON_VCC 12V: 12.65V
        BL_ERR: 33.6mv
        POWER_ON: 3.4v
        STBY3.3: 3.5V
        GND: 1.6mv
        REG 12v: 12.65v
        REG 12V: 12.65v
        REG 12V: 12.65v
        GND (TCON): 4.1mv
        TCON VCC: 12.65
        Yes I removed the cover from the t-con board
        • lmcancu
          • Oct 2009
          • 158
          Screen is very faint blue. I saw half the screen when the issue first appeared, after I powered off/on, I no longer had any picture just the backlight. The screen just shows a faint bluish color with the start up musinc playing.
          I also tried removing the ribbon cables one at a time to see if I would get back half a screen, but no picture just the blue from the backlight
          • Diah
            • Feb 2013
            • 6366
            did you hear sound???
            • lmcancu
              • Oct 2009
              • 158
              yes. The spa music after I did the factory reset
              • Diah
                • Feb 2013
                • 6366
                check T-CON fuse if there 12V at both side... if yes... then disconnect the 2 LVDS from T-CON andf feed the T-CON fuse with 12V from the PSU 12V. turn on.. see what you will have on the screen...... if the BL didn't come on at this test... use touch light to inspect the screen behavior.
                if screen black no color... replace T-CON
                • lmcancu
                  • Oct 2009
                  • 158
                  This fuse correct? I measured 12v on each side. And the LVDS cables are the 2 cables attached to the top right? Do I leave the third connector to the right connected as well? And how do you recommend I feed 12V from the power supply to the fuse? and which side of the fuse? Where do I get the 12v from the powe supply? I guess its from the third connector to the right?
                  update: I removed the 2 LVDS cables, and just verified the voltage on each side of the fuse. It was 12.65v. I don't understand how feeding 12v from the PS to the fuse will do anything since there is already 12v there?
                  • Diah
                    • Feb 2013
                    • 6366
                    no need to feed the fuse as you said you have 12V on it after you disconnect the 2 LVDS ( the 2 on the top close to fuse
                    yours T-CON take the 12V from the socket close to LVDS... so just turn on and see if the screen have any color pattern... if BL didnt on use light to inspect
                    • lmcancu
                      • Oct 2009
                      • 158
                      Backlight is on but no picture with or without LVDS cables connected. I get just a blue screen as shown in the one of the pictures I posted
                      • lmcancu
                        • Oct 2009
                        • 158
                        I was watching Nick's TV on YouTube and to determine if the main board was faulty, he disconnected it and then put jumpers between 3.3v STBY and Power on, and between tcon on and BL on. He then showed that the TV was doing a color pattern test and that indicated tcon, etc was good. Is this the right approach?
                        • Diah
                          • Feb 2013
                          • 6366
                          if this exactly true ,,, then t-con and panel and power boards are fine..... the rest MB
                          • lmcancu
                            • Oct 2009
                            • 158
                            Should I use a 1k resistor instead of a straight jumper to test?
                            • Diah
                              • Feb 2013
                              • 6366
                              for people not sure or first time they do,,, will be recommend to use R 1K or less to avoid any damage if they missed with pins assignment.
                              • lmcancu
                                • Oct 2009
                                • 158
                                Ok thanks! So they way I understand it, is that the 3.3v STBY pin will turn the TV on when connected to the Power on pin. Once the TV is on, it will provide 3.3v to TCON on. Then jumpering that pin with the BL On provides 3.3V to the BL so that it can turn on?
                                • lmcancu
                                  • Oct 2009
                                  • 158
                                  I tried the jumper tests: I jumpered STBY 3.3 with Power ON, and BL ON with TCON ON as shown in this video
                                  https://www.youtube.com/watch?v=4afrEbS5mZw
                                  But instead of BL turning on when plug in the TV, I get the 3 Red LED Blinks on the LED driver board. Anyone knows what that means? Picuture of the LED driver board attached
                                  Note, I jumpered the pins prior to plugging the power cord. Do I need to jumper them after the power is plugged in?
                                  • Diah
                                    • Feb 2013
                                    • 6366
                                    main boards should be disconnected from T-CON and Power boards and LED driver boards
                                    jumper put them in place then plug it in wall
                                    • lmcancu
                                      • Oct 2009
                                      • 158
                                      Yes I did exactly that. Main board was completely disconnected from all other boards. The LED driver and T-Con boards were connected to the Power Supply board.
                                      Note to be exact: I jumpered pins 2 and 3 together (Power On and STDBY 3.3) from Header 1, and pins 1 and 13 together (BL ON and TCON_ON) from header 2.
                                      Please see picture attached
                                      • Diah
                                        • Feb 2013
                                        • 6366
                                        led driver boards need to disconnect from the boards side to avoid any short... same to LVDS at t-con need from T-con side disconnected
                                        u can ignore BL_ON... just use power on and T-CON on.... use torch light to inspect the pattern on screen
                                        if there nothings... you need to show us the edge puffer boards of the panel left and right.... see if there are U ribbon installed at the middle of each side
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
                                        • Spc.
                                          Sony Bravia KD43XF7596BAEP - Android no picture
                                          by Spc.
                                          Greetings everyone.
                                          I also have Sony Bravia, model:
                                          Sony Bravia KD43XF7596BAEP - Android.
                                          What happend is that image dissapeared while we were watching tv.
                                          Diagnostics:
                                          1. TV turns on, no errors
                                          2. Backlight turs on, no errors
                                          3. Power indicator turns on, white color, no errors
                                          4. Menu works on android, you can hear sound while switching channels
                                          5. Volume up and down works via TV remote and via buttons
                                          6. Tunner works, HEVC / MPEG-4 decoder works
                                          7. I get audio from channels
                                          8. No picture is present,...
                                          05-19-2022, 04:28 AM
                                        • KYBOSH
                                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                          by KYBOSH
                                          Previous owner said TV just went blank one day.
                                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                          I just downloaded the Sony KD-75X7800F Service Manual and...
                                          11-19-2024, 10:12 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
