Sony Bravia XBR-75X850D
  • nomoresonys
    • 12328
    • U.S.
    #41
    It's not 6827 but it will work.
    • lotas
      • Jan 2016
      • 4835
      • Russia
      #42
      v 6.827 This was the latest firmware (with Android 8.0 for the Asia-Pacific region).
      • HS13
        • Feb 2014
        • 17
        First Thank You Lotas and Nomoresonys. I'll try to update but do I have to rename the firmware after extract to the USB?
        • Diah
          • Feb 2013
          • 6541
          its also last firmware for N America... but Sony when firmware removed from its online portal it mean there are concern issue with FW. and they will release other one..
          No one asked the owner who said he had amber and green LED how it come and why....if he replaced board or whatever the reason..
          i think with Sony no need to hurry,,, with answer
          • lotas
            • Jan 2016
            • 4835
            • Russia
            #45
            Here you need to select USB flash drives that are not large in size (4-8 Gb); not all flash drives can support the update. The flash drive with the update should be inserted about a minute after the LEDs start blinking. You can rename the file if the update does not pick up. It is better to have a USB flash drive with a built-in LED, then you can see communication with the TV. It happens that the update takes place with a black screen, there is no need to rush and press buttons on the remote control, take out the flash drive, turn off the TV, the update can last about 30 minutes. and more.
            Yes, also, if everything goes smoothly and the TV is updated, then I advise you to do a complete reset after the update.
            • nomoresonys
              • 12328
              • U.S.
              #46
              You are correct sir, it IS last firmware for N.A. They pulled the firmware in Jan. 2022, thats about 6 years, some pull it in 3 or less years. I think the main reason they pull it is exactly what you would expect, to make it harder for people to do simple fixes of their tvs, in hopes that they will buy a new one from them. If you contact them you can probably get it, still better than some "brands" will do: https://www.sony.com/electronics/sup...850d/downloads
              • nomoresonys
                • 12328
                • U.S.
                #47
                Just contact them and tell them you need the latest firmware, and the answer if asked is always...I bought it new with cash and the receipt is long gone but doubt that will come up: https://www.sony.com/electronics/sup...tware/00269731
                • Diah
                  • Feb 2013
                  • 6541
                  any firmware for different region will not updated on other sony version. because however it passed key authorization, as this keys one for all but after that its command to read build.prop content at system--- & recovery as well as kernel do forget... man should learn about Android how it work more than search and post things didn't work.
                  • nomoresonys
                    • 12328
                    • U.S.
                    #49
                    Good advice, as usual.
                    • HS13
                      • Feb 2014
                      • 17
                      Still have no luck. maybe go to recycle (Amber and green light blinking)
                      • nomoresonys
                        • 12328
                        • U.S.
                        #51
                        I don't do a lot of updating, if you follow Diah and the ones who do it often, seems like you should be able to update it BUT you have to follow directions exactly and try the different things they tell about, sonys are finicky, try different usb drives and keep it 4gb or under as suggested.
                        • JUCaESAl
                          Sony bravia KD-65AF9
                          by JUCaESAl
                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                          10-20-2025, 04:03 AM
                        • PopsCaps
                          Sony Bravia KDL-40V2500 that will not power on
                          by PopsCaps
                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                          I do not hear any sound and I cannot see any backlight.
                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                          03-25-2025, 11:23 AM
                        • justin35
                          Sony bravia kdl-43w755c - boot loop
                          by justin35
                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                          from what i read online it looks to be an emmc issue…
                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                          i took out the board and say an samsung 16gb emmc
                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                          i could try to put one instead of the 16gb one, but will it work?
                          where do i get the software from?
                          any help will be much appreciated!...
                          03-06-2024, 12:26 PM
                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                          10-16-2024, 05:15 AM
                        • Spc.
                          Sony Bravia KD43XF7596BAEP - Android no picture
                          by Spc.
                          Greetings everyone.
                          I also have Sony Bravia, model:
                          Sony Bravia KD43XF7596BAEP - Android.
                          What happend is that image dissapeared while we were watching tv.
                          Diagnostics:
                          1. TV turns on, no errors
                          2. Backlight turs on, no errors
                          3. Power indicator turns on, white color, no errors
                          4. Menu works on android, you can hear sound while switching channels
                          5. Volume up and down works via TV remote and via buttons
                          6. Tunner works, HEVC / MPEG-4 decoder works
                          7. I get audio from channels
                          8. No picture is present,...
                          05-19-2022, 04:28 AM
