How to clean the polarsing layers?
  • rvh
    • Feb 2020
    • 9
    • Netherlands
    I've repaired a TV that i found standing on the streets for the garbageman. Unfortunately, the tv got wet and there was -at least, that's what i think- some moisture behind the panel. During two weeks, it became less and less, I think the moisture is gone 99%, but i still see some residu on the sheets
    It's harsh to see when looking straight to the tv, but it is visible from an angle.
    Is it safe to clean these layers and if so, how do i do that?
  • petehall347
    • Jan 2015
    • 4427
    Re: How to clean the polarsing layers?
    i have in the past gave them a very gentle wipe over with lint free cloth . you have to watch the static though one spec of dust turns into a mountain . .
    • Storyteller12
      • Jun 2020
      • 624
      I found one and the same condition outside. I took it apart and cleaned the sheets with alcohol and let dry a few minutes and put back.
      I have had one though where the sheets stuck to each other after being left out in the rain and peeled when separating them.
      • Diah
        • Feb 2013
        • 6397
        raining water not clean thought... also the Tv had some dust from old time so ... the sheets are kind of Nylon ... no worry about cleaning them.... only notice that they should being straight at cleaning.... so
        Moister need water to get the fleck out... use distillery water to wash them complete from any side it effected with moister.. after dry use lint free cloth ..
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          The back of the screen and the layer behind it are the usual parts that will have stains.
          Alcohol actively deforms the plastic, but a quick wipe will do nothing bad.
          • David Stroe
            AOC CQ27G2U/BK - in need of data sheets
            by David Stroe
            I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
            I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
            Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
            Main Board: 715G9500-M0C-B00-005K
            T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
            If someone could please provide any of these data sheets, it would be awesome....
            05-31-2025, 11:12 AM
          • Raulnn
            clean hisense inner sheets
            by Raulnn
            Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
            01-22-2023, 05:19 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • withalligators
            Looking for best replacements for Capxons, but can't find data sheets
            by withalligators
            Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
            1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
            1 x Capxon 1000uf35v...
            03-25-2022, 02:30 PM
          • Ogre262
            SAMSUNG UN60JU7100 - Order of LED light diffuser sheets when re-assembling TV
            by Ogre262
            I recently replaced an LED strip in my SAMSUNG UN60JU7100 TV. I managed to do that with little difficulty.
            My problem is that I did not mark the order of the 3 diffuser sheets that go between the LED lights and the screen.
            There a 3 sheets
            1 thick white opaque plastic (about 1mm) with a smooth side and a rough side
            2 silvery translucent ones about the thickness of card stock
            A. One that is the same on both sides
            B....
            02-10-2019, 03:35 PM
