Re: Medion 42" plasma not turn on
In simple steps:
The hybrid on the Z-sustain is prone to shorting.
The Z-Sustain draws a lot of power.
The same hybrid is used on the Y-Sustain
The Y-Sustain draws even more power
The power supply shuts down when the Z-sustain is connected, but comes up when the Z-sustain is disconnected.
Disconnecting the Y-Sustain has no effect on the performance of the power supply.
THEREFOR It is a logical conclusion that at least one of the problems is caused by the Z-sustain.
It is noted that this TV seems to have at least three problems. I am concerned that this may be a 'junk' chassis made up of a number of bad cards all placed in a TV with a bad panel. But even that can be educational.
(If I learn the part number of the Y-Sustain I MAY be able to verify a short. It is even possible that by checking resistance between the various power lines and ground on the Z-Sustain forgonati may be able to verify a short.)
PlainBill
In simple steps:
PlainBill
